  • Replies 184
I was actually being nice I hadn't spoke to Adrian at all and to be honest I don't give a f*ck as all I was doing was congratulating you on having the car ready and all I get back is crap like "P.S. burnouts are for pu55ys who can't get low e.t.'s"
but I'm the one with attitude :cheers::(:)
Guest two.06l
yeah im sorry if that you thought that was directed at you but...as i thought adrian was the only person who knew about the 405 i thought he must have told you, so the burnout comment was directed his way. Sorry again if offence was taken. Thanks for the congrats. see ya sat if you dont ring.....
This is fu(king awesome!
BTW cheaterererers, just got this from www.sportcompactgroup.com so there'll be no piking out like little pusseh's on the day! Got it?
In a perfect world it would be great to have an event as pre-entry only but in the busy lifestyle we all lead these days it isn't always possible. So for all of you that haven't had time to get your entry form in because you've been busy working on your vehicle etc you'll be able to enter on the day.
    • Hi Guys, Looking for this piece if anyone can help out.   https://tfaspeed.com/products/nissan-skyline-r33-gtr-rear-trunk-finsher-panel
    • How did you go with your problem? End up fixing it. Have a y34 aswell vq30det
    • But if I smoke test 5th cylinder it’s all ok, no leaks  when I try with 2nd it’s leaking exhaust and intake, it doesn’t come from oil dip stick.    so maybe when car was running poorly, rich or sth. Spark plugs were black and covered in charcoal or sth lookalike. could potential contamination make valves not seal properly? is there also a possibility that rb’s don’t have equal performing cooling passages  meaning back of the engine will be hotter than front. Can this cause improper wear if engine was running under load for short time? Or carbon build up could just burnt from 4-6 and is still on 1-3?   I out of my head like really. Timing is as manual crank-exhaust 47, exhaust-intake 38 at this point I thinking about give it a try and make another 500-1000km and check if anything change, if not I will most likely disassemble engine head /or whole engine and send it back to rebuild. It’s killing me
    • Thanks Duncan, I don't have a GTR these days mate. Gone soft..
    • Yeah. air pressure leakdown test is where I would be headed next here, using one's ears to determine whether it's the valves or bores/rings leaking...
