Alpine MRV-1507 Specs
Description:
This model put the "Amp" in amplifier. Perfect for multiple subwoofers, this road tested and time proven V-12 amplifier keeps playing when you need it the most. The Audio Quality MOSFETS and Subsonic Filter restore power and produce killer, tight crisp bass. Of course it's also Bass Engine Ready meaning it can handle the juiced signal from an Alpine Bass Engine Equipped head unit. • Max Power (EIAJ) 450Wx2 (4ohm; Stereo) 1500Wx1 (Bridged 4ohm • 12V RMS Continuous Power 4ohm; Stereo (0.08% THD) 150Wx2 2ohm; Stereo (0.3% THD) 300x2 Bridged 4ohm; (0.3% THD) 600x1 •14.4V RMS Continuous Power 4ohm; Stereo (0.08% THD) 225Wx2 2ohm; Stereo (0.3% THD) 450x2 Bridged 4ohm; (0.3% THD) 900x1 • S/N Ratio 105dBA • Frequency Response: 10-50kHz • 24dB LP/12dB HP Crossover (30-200Hz) • 1-Band Parametric EQ (30-200Hz) • Subsonic Filter (15Hz) • Fan Cooled • Extra Large Gold Plated Terminals with Wire Insert Capability •Top Panel Power LED •4 Volt Input Capability • Continuously Adjustable Crossovers • DC Straight, STAR Topology & Duo-B Circuitry •DC-DC/PWM MOSFET Power Supply
Most people know what this amp can do.
Pics available email me
[email protected]
Offers $500+
https://www.sau.com.au/forums/topic/63267-alpine-mrv-1507/
    • It's new almost. Under a year old i think and I've tested it twice at supercheap
    • Glue the head from a Pez dispenser on it. Goofy, or Winnie the Pooh, so something.
    • Adjusting the idle screw is usually (emphasis on usually) just covering up deeper issues. Stuff like the cold start valve not closing properly. Throttle shaft seals on the way out. Coolant temp sensors getting out of spec. Coolant temp sensors especially can be a bear to diagnose because they can fail subtly. My dad just spent weeks chasing down his high idle. He cleaned the coolant temp sensor and everything but the resistance curve just drifts over time and if it's been 20+ years they also get super slow to respond as well. Has a massive effect on fuel economy as if it's off the ECU is going to run richer and command high idle for far longer than it should otherwise.
    • How old is the battery, it's more likely your battery is on its way out.
    • I reckon you'd get 90% off. My washer doesn't get between spokes very well. Haha! I love my Gerni!  Argh! Steam cleaning has its place for sure.
