say you have a dead RB26 engine....and you can't affod to buy another engine and your mate were like donating an RB25 to fit into your GTR..and you agreed to do so.
what would you call that one ? still a GTR ?
it would still be a GTR [modified]. it would also be a tragedy of huge proportions.
  • Replies 163
Here's a pic from Adelaide
 Has GTR badge & TURBO 1 number plates.
 But here's the twist..it's not even a GTS-T..just a GTS!!!
hahha
nice looking car too, but why the badge?
(p.s I made it bigger for you :( )
Theres a black gtst that cruises along nerang broadbeach road every now and then complete with gtr badge. I know a 32 gtr with gtst badges. I know a 33gtst with a gts badge on it.
as for things on my car that people dont want, im pretty sure i got lots of that....
no one said people cant do what they want, all thats been said is people need to think before they do something that may or may not cause them to look a bit silly.
what about people that put stickers on their car like Gready apexi trust HKS etc even though they dont have any on those brand named parts in their car ????
What about people who can't spell Greddy. That really sh1ts me.
I'm gonna start a thread about people who are illiterate.
jks.
:D
This wouldn't happen to be a green 33 with a hi-mount force induced drift chicken wing
would it? :):D:D:D
Off topic but... BelGarion what have you done to your ride ?
You could stay unique while I stay in NSW and vice versa.
I know it aint easy being green. :(
El Bee :D
ok ok ok, i sorta kinda read through this thread but if i say somthing someones else has said then i dont carem drill me all u want, i luv it:)
gtr badges on gtst is relative to any friggin other astheitic mod done to ya car. who has a gtr wing or their gtst, or front bar, or anything else? why should a badge be any different?
i aggree that people with gtr badges claiming to people that their car is a real gtr is stupid, but shit, how many times have i heared people with a gtst with a front mount and exhuast claim they run low 11`s? hahahaha if people wana lie let em go!
gtr badge on gts= same shit as any other body mod
what about putting mspec front bar on a non mspec gtst, is that bad? didnt come like that from the factory, oooowwwww you bady
i think people are either spitefull cuase they dont have as good cars or want a gtr and cant ever get it, just plain boared or really have some freaky issue
i must admit gtr badges on gts do crack me up, but there are alot of eauivalent mods that do the same
wat happened to a rice thread? spot waht u think is heaps ricey and crappy, but still, people might still disagree?
Umm no it is not. A badge is different by the very nature that it is verbally stating that "my car is this" when it is not. It is about deliberately misleading people who do not know any better.
Yes, it is wrong to lie. But if you are lieing, then you can not whinge when you are caught out.
Ummm no it is not, see above
Missed the point again Rodney. Putting a body kit on a car is not verbally stating in written text that your car is something else. Plus a front bar can be put on for aerodynamic reasons and to allow for the fitting of a large FMIC. Bodykits, rims, paint, wings, etc etc, don't verbally state in written text so everybody can read, that the car is something that it is not. So definitely an irrelevant analogy on your part.
who cares what their justification is for lieing, they are still liars.
If you are gonna put them on at least put them on the right spot and then shot yourself in the foot :)
As for when the REAL GTR abosolutley thumps you, you'll then know why they wear them so proudly. And all your doing is soiling their great name.!
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
