Guest Variable
The dump pipe takes the exhaust gases straight off the Exhaust wheel of the turbo and is basically just an elbow (maybe about 30cm long max). The front pipe then bolts to the other end of the dump pipe and usually goes through to the catalytic convertor.
On a GTR where you have two turbos, there are two dump pipes and then the frontpipe is basically a big "Y" to join the two gas flows together before the cat.
Hope that helps.
