Noise in your steering wheel? (with horn problems?) (Airbag wheel) --> Read this.
Ok this is to clear up any issues people may be having about funny clunky/metallic noises coming from their steering wheel when they turn corners, here's the lowdown. Also, this comes in conjunction with your horn intermittently blasting on for no reason while you turn corners. (i've tried to include as many keywords in case people are searching for this too)
This noise, which is best descirbed as a metal-to-metal 'tink/clunk' noise, which can also be felt through the wheel occurs most obviously when turning the wheel to 180 degrees and beyond. It can also be felt, along with a lighter 'tinkle/rattle' noise when travelling along bumpy roads, train tracks, etc.
As a bit of history, my car first developed this noise after i had travelled over some unmade, corrugated dirt road and has continued on from there. situations like this can cause the problem, and from there on you're stuck with this annoyance.
The reason i write this is because this annoyance turned into a 'not roadworthy' the other day when i took my car in to get its rwc ticket, ready to sell the car. The guy claimed that because he doesn't have a technical knowledge of the steering wheel, he couldn't rule out that it was a problem with the airbag (even though the airbag light came on and disappeared as prescribed) and therefore he wouldn't give me the rwc.
Cut a long story short, after being hassled by many nissan dealerships about how they don't have a manual for the car and therefore they can't work on it (how incompentent must the mechanics be to need a book?), and other people wanting over $200 to fix the problem because its 'technical' and involves a shock-horror 'airbag', i decided to take matters into my own hands.
If you have this problem please do not be fooled into thinking its some massive effort to fix.
Quite simply, my routine to fix the problem (all up 20 mins) was this:
Phone Repco, ask if they have a T50H attachment (T50 torx tamperproof)
Go to Repco, buy T50H for $9.09
Come home
Disconnect battery, pump brake pedal (discharges any extra charge)
Pull airbag fuse
Remove Shroud around steering wheel (5 phillips head screws)
Disconnect airbag wire (biggish brown clip in right of steering column, covered in foam, sits just next to ignition)
Disconnect other connection of airbag wire (right under steering wheel, centre-not even sure if i did this)
Pop out two little plastic covers out of the side/rear of the steering wheel
Use T50H with ratchet, undo bolts-mine needed some arm strength to initially get moving-CAREFUL-the airbag wants to fall foward with them out
VERY CAREFULLY and slowly remove airbag (it's attached to the front of the steering wheel) about 4inches
Sight noise-causing-weight, sits at the top of the wheel, in a little 'holster' type arrangement (as soon as i touched it a bit i recognised the sound immediately)
Remove annoying little weight
Throw weight in bin & swear at it
Place airbag back in place
Tighten T50 bolts
Replace plastic covers
Re-connect wires
Replace shroud, do up screws
Reconnect battery, replace airbag fuse
Check car starts(a good sign)/airbag light boots up (and then disappears) ok
DONE
Now, i don't know about horn function after this has been done, it should be ok, but i had already diverted the horn wire to a switch (horn is the brown one in connection of 4 wires-follow them from the steering wheel back-you splice*not divert* the common ground-black-to your new switch as well) a few months back, so i still had horn functionality whilst i didn't actually know what the problem was inside the wheel.
And also, on my series 1 anyway (1995), you don't need any special gadgets to reset the airbag light, it works fine :)
I can happily say now, however, that it's all fixed and thank god the problem is gone for good. For those with an inquiring mind, the weight is there as a counter balance for road vibrations, honestly the difference is like 10% more daihatsu-feel without it, within like a week you won't remember any different, plus if you've had the problem for months like me, having a noiseless steering wheel is heaven on earth :D
So, if you have any a-hole mechanic/nissan man/import specialist telling you its a tough job and it will cost lots, tell them to stop being a clown!
Any questions, fire me a PM
PLEASE-i bear no responsibility for anyone taking apart steering wheels that have airbags in them because there is always is a chance they can go off (although in theory they need charge to). I have merely documented my process. Also please note it is totally illegal and against ADRs to replace an airbag wheel with a non airbag wheel!
um yeh well documented in drips and drabs and intermingled with lots of other stuff about police helping people with beeping horns, people rewiring brakes to horns, people not knowing what the problem was, etc.
thought i might put it all down from problem definition through to cause and solition - plain and simple in one post so the next poor bastard that has this problem doesnt have to trawl 5 posts over an hour like i did :) or worse still get ripped off by some b/s artiste mechanic!
just trying to make the world of cars a bit easier to live in dude :D
Naiwiboo, this is an excellent documentation of the problem. I've had this problem for a few days now and I believe it's due to the stiffer suspension that has recently been installed giving the car a harder ride. I removed the shroud around the steering yesterday only to discover that the clunk was coming from within the steering/Airbag. Thought it was a difficult job, but now sounds too easy. Thanks heaps.
For your info I don't have any associated horn problems!
  • 3 years later...
I had this exact problem and I fixed it by following these instructions exactly, and it worked like a dream!
It was always rattling around from the day i bought it, but one day it started setting off the horn on almost every corner I took. It was funny for all my friends, but had to be fixed. I did everything mentioned in the first post except for "Disconnect other connection of airbag wire", as it was too hard to unclip, and wasn't necessary as the previous step already disconnected the other end.
I ended up just cable tying the counterweight to the brackets inside the steering wheel cos I figured Nissan put it in there for a reason so I didn't want to just throw it away.
Thanks!!
great write up....saved me thinking. heres a pick to contribute to the thread. i lacka-banded mine so it still keeps some gyroscopic functionality..lol
good idea! i wonder what the original idea was behind suspending it with rubber bits? maybe the faster you turn the wheel the more help it gives you (centrifugal force, etc.). but hopefully those rubber bands wont deteriorate after a few years in hot sunlight and cold winters and stuff...
  • 11 months later...
6 screws in the column shroud, just did mine almost snapped it of before i found the sixth screw at the back!!! but all fixed now took about 15 mins!!!
    • Might piggy back off this thread since there's been a good discussion about PWM.   I purchased a Walbro 460 F90000267 and have been looking into PWM to understand it. It was purchased more of a future proof as my original OEM fuel pump died (r33 below 200kw) and figured I'd just upgrade it to this. That's when it hit me that a pump this big can cause more dramas with such high amperage draw and heating of the fuel pump being on 100% all the time in such a mild setup.   I have a Nexus R3 and slowly collecting power mods but I was looking into the PWM feature on the NSP software:   Then looking at the graph from the fuel pump:     Am I safe to assume reducing duty cycle to 50% for example would make the pump run like a 230/lph ? Where does the PWM come in all of this ?   I've gone down the rabbit hole of PWM fuel pumps and it seems there are many differing opinions on how to go about it 😅
    • Thank you, this will keep me busy for a bit.  I will update progression.
    • That specific one would be an exchange part, meaning I'd have to send mine to them. Plus it looks like a non AWD sump, which won't work for me. There is one or two shops in my country that I can ask to do a sump extension job and it'd most likely end up being cheaper than sending mine to AUS or NZ and getting one back, and quicker too.
    • Rear turbo is leaky, most likely at the oil drain. From what I could see with my boroscope it seemed to have seeped out at the very top of that return hose. Is it possible that the oil climbs up that hose to then leak out? Yup, coolant leak on the hot side of the engine, only noticed after seeing clear rusty residue in the block right from the turbo oil feed downwards to the pan, and red droplets hanging from the pan. No clear sign yet from where it comes, and most of the lines there are hardlines right? Last year, seeing those red drops, I thought it was power steering, will be glad if that is not leaky at least. Another leaking hose I found by chance is the lower of the two heater core hoses coming from the firewall to the back of the head. That one is not too bad to get to if I have to replace.
    • I think for response I'm already kind of out there no? he -5s are not the best pick for that as the Internet tells me. Maybe I should switch to -7s while I still can? Though that almost definitely warrants an engine pull along with the other issues I have.
