  • Replies 44
Being a former "rexy" owner, my advise is don't drive the GTR like the WRX.
Yes, the GTR does drive like a RWD. It only engages 4WD mode when the rear kicks out. Don't try to counter steer too much when the rear kicks out. Use about half as much and keep your foot on the throttle.
Like any 4WD, brake before you enter the corner to balance it out. Failure to do so and it's understeer all the way.
You may think the WRX is faster out of corners, but in reality the GTR steps all over the WRX.
Guest Nismo_Freak
Also note that the WRX is lighter and has less torque than the GTR which makes the AWD system "lighter" feeling meaning it does have a gross over/understeer. The Subaru system is a 50/50 distributed AWD where as the Nissan system is a 40/60 (rear gets the larger bit) to make the car react more like a RWD car. From watching videos I have noticed that the AWD system kicks rather sharply when it gains traction. Usually AWD systems like to push out when they are under load in corners but the GTR should remain fairly balanced with its spring rates, suspension, wieght distribution, etc. Just go into the corners and react is all I can say... its when you predict what the car is gonna do when you get in trouble. Just whatever you do dont lift throttle when you are cornering hard... it can make you spin out.
The WRX is idiot proof. Well, almost. It's more forgiving. I don't know how ram-raiders roll and lose control of WRX's.
Go to the race track on a wet day and you'll learn very quickly. In the wet, you don't need too much speed to get it sideways and see how the 4WD works. Just don't speed too much on the straight.
minh.. best way is to just take it to a track and see how it reacts when pushing it.. tis much better to find out on the track than on the road :cool: though it is kinda fun on the road though..
actually theres a track day today :) .. should have gone given it some :) actually bugger it... jump in the passenger seat.. adn ill take u for a drive.. just gimme a couple mins to sort out what to do with 4wd
i always find slow in fast out works with my gtr keeping the pedal down seems to straighten them up well , you can always fit a 4wd controller wind on a bit more drive on the front similiar to the n1 and they loose that taily bit.
Stevehttp://www.justjap.com
Hey steve thanks for the reply?
How much is this thing your speak of?
Having previously been a WRX owner also the Wrx has shocking understeer which limits your turn in speed drastically but as the 4wd system is constantly in operation it comes out easier (not faster but it is easier to get it right.)
The problem with the GTR's is that the Latitudinal Sensor sharply reduces drive to the front wheels whilst cornering thus bringing on vast amounts of oversteer if the driver wishes or allows. This will greatly effect your cornering speed especially your exit speed. As mentioned above the best way to fix this (and for me it should be fixed by anyone who cares about their cornering potential) is to fit a torgue spliter (or in real terms an amplifier) so that you can control the level of control that the latitudinal sensor has on the car. This will allow the bias to the front wheels to increase durin and exiting corners and will greatly improve the cornering and predictability of your cars cornering. This makes the car incredably neutral and will allow vastly higher cornering speeds and much earlier exiting apex's.
I built my own torgue spliter and am currently looking to re config the board etc for it but will be happy to build some if enough people are interested.
Mick.
Are you guys talking about torque splitters like the HKS Torque split controller?
with things like this if you give the front more then is this a constant thing meaning that when you drive in a straight line you will have more drive to the front still? or is it adaptive or progammable?
400hp,
I do not know what the HKS splitter does but the one that I built does not drive the front constant it simply reduces the effect that the latitudinal sensor has on the attessa.
The GTR's have three sensors (2x Longnatudinal (to measure + & - g-forces) and 1 X Latitudinal (to measure sideways g-forces). Once the longnatudinal sensors measure a certain amount of g-forces it will engage the front wheels as it has assessed that the car can be wheel spinning. However once you turn a corner hard (you must be under acceleration for the longnatudinal sensor to bring the front wheels in) the latitudinal sensor REDUCES power to the front wheels, thus making the car very "taily" in it's handling. What my splitter does is allow you to dial in how much influence you want the latatudinal sensor to have and thus dictate how much front wheel drive you want durin cornering whilst accelerating.
It must be remembered that the longnatudinal sensors are the once that brig the front wheels into the equation so unless you are accelerating you still will not have any 4wd exactly the same as it does standard. The spliter simply reduces the power of reduction that the latitudinal sensor has. In a straight line the car will perform as standard. In corners however you can dial in how much front wheels you want.
You could achieve that possably by changing the sensor (lat) but with the dial so that it can be varied you can alter it as you desire for such variances such as wet or dry, slow or fast corners. It makes the car vastly safer and greatly alters tha handling characteristcs of the car making it incredably neutral.
One of the things that I have always found a little disapointing about the GTR's is their handling (I will say the same for the WRX except it is far harder to fix) due to the oversteer problems that they suffer. The splitter cures these problems and makes the GTR one very imrssive handling car, for a road going car.
For the record I also encourage people to get rid of their hi-cas if they wish to improve handling.
Hey a good set of Koni's will also help.
Mick.
    • Can perhaps see how the R33 appreciators would think so.
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
