A lightweight flywheel is a good move.
Accelleration is improved full stop.
Torque decrease ----- false. Absolute rubbish!!!
Can't go up hills as quick ---- false. as above.
As a reccomendation go get a Ogrua lightweight flywheel or something similar they weigh 4.8kgs, the drivabillity is very good for the street with stock like characteristics.
Do not lighten the factory unit. Cast iron only has strength in the outer skin. If you take enough material out you drastically weaken the unit. There are plenty of cases of these sort of flywheels exploding and causing damage and injury. There are also plenty of people going around with them who haven't had one let go but, when you consider the aftermarket ones are much lighter still and being chromemolly will never 'explode', for $500 who would argue with that.
  • Replies 69
I think the less torque theory comes from Gran Turismo :P
That 'simulation' game? :) hehehe
I was thinking about it a bit more tonite. How can it lose torque? You pull the engine out its still got the same amout. At the wheels it might make a difference, but after driving round tonite thinking about it, I dont think it does hey. And just listening to the rev speed of my car to other rb20s I think it makes a fair difference. BTW I have a JUN lightweight wheel in mine.
Chromoly won't explode but heavy-ass clutches and indiscriminant use can 'burn' straight through them.  Food for thought.
Adrian
i also heard the same adrian stop me from getting one when i replace my clutch didnt like the idea of destoring it
i have one in my daily driver
went from a 13.4kg stocker to a 4.5kg lightened one, that has most of the weight on the inside and very little on the outside
this one infact VV
its alot better IMO, i have no problems using it for driving in heavy traffic, i consider it to be an all round improvement. only different is you need to slip the clutch a tiny bit more to engage it at low speeds, and that it will punish you more if you make a bad gearchange. but really at the end of the day you will be a better driver for having one and it improves the cars revability and acceleration, not by a huge amount but a definate improvement. took me about 4 days to get used to and since then i havent looked back
People that have driven my car with the lighter flywheel always commented how it rev'd a lot easier.
this was before i did all my mods and it was making ~185-200rwkw like most melb R33's depending on your dyno choice.
Adrian
I think you got mixed up there.
The metal used in the construction of the aftermarket flywheels is harder than cast iron. It is in fact the lightened cast iron flywheels with no hard outer skin left that get eaten through, that is why they explode and the chromemolly ones don't . All triple and quadruple plate clutch systems designed for mega horsepower utilise chromemolly flywheels as a part of the package not cast iron. Cast iron flywheels require 'skimming' when replacing even organic based factory clutchs. 'Chromemolly steel' never requires this. Some really good flywheel packages are even gas nitrided on the friction surface.
Well guys I bought the light weight flywheel from UAS today, and had a chat to John as always... They're real helpful over there I tell ya!
This one weighs in at 4.8kg.
Anyway, here are some photo's that I took of it. It'll be installed tomorrow with the daikin heavy duty clutch.
click thumbnails to open the photo in a larger window
I'll know the results tomorrow.... (fingers crossed ay)
wil..
Clutch and flywheel are in.
Torque loss - None that I can really feel. The car however picks up a lot nicer than it use to. It runs through the rev's significantly faster than before.
The clutch is rated as having a higher clamping force than before, yet the pedal feels "lighter" than it use to??? What's the go there.
The new clutch grabs a lot harder than the old. That much I'm sure of. But I'm just curious as to why the pedal feels lighter? I always heard that replacement clutches with higher clamping loads would be heavier in feel.
The extra clamping force is offset by changes in the diaphram pivot point - so the clutch feels lighter but you need more clutch travel to disengage.
I had a molly lightened flywheel on my RB20DET, not quite as nice looking as yours though. :D
It is true that it needs more rev's to get off the line but I did find it accelerated quicker.
It felt as the torque made from the motor wasn't absorbed in the heavy flywheel before accelerating the car, instead more of the torque generated by the motor was able to filter through to the rear wheels quicker and easier accelerating the car quicker.
It also felt as if it didn't bog down as much, boost felt a little more snappy.. :)
It was a nice little mod. :(
i got a 2.5kg lightened fly for my car worth $900 apparently... just waiting for the work to finish b4 i can test it out
Hmm you sure it weights 2.5kg??? If so it must be made of carbon kevlar or some other exotic material?
I have 4.8kg chromemolly and the engine revs upto redline alot quicker and i dont see any negative effects with one
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
