  • Replies 69
Hmm you sure it weights 2.5kg??? If so it must be made of carbon kevlar or some other exotic material?
I have 4.8kg chromemolly and the engine revs upto redline alot quicker and i dont see any negative effects with one
it was second hand sam from XTC picked it up for me out of a nismo clutch n poped it in... just waiting for my car!!!! he told me all about it i cant remember what it was but he researched it n new worth $900 n weighs 2.5kg unless my hears gone thats what he told me
Why do they make clutches pretty colours when they go INSIDE THE BOX!!!?!?!????!?!?!
So some crazy person will take the effort to make a see-thru housing with neon's that'll let you see the flywheel spin? LOL :)
U must have heard 4.5kg.
What is it made of? coz $900 is not much if its some exotic material
  • 2 years later...
sorry to bump this up. after reading through the whole thread Im still not very clear on one thing: does it really gives you faster acceleration say for 0-400m drag racing? or does it just "feel" faster because it revs faster?
Ive got a single plate Jim Berry clutch to be installed next week, if light flywheel is as beneficial as most you say maybe i should get one whilst the gearbox is out?
is this a good flywheel to get?
"Exedy - Single Sports - Light Flywheel
Low mass is a good thing when it comes to high-performance flywheels, which is why the lightweight aluminum Exedy flywheel can help your sporty street ride or weekend racer develop more drive-wheel power. A flywheel is basically an energy storage device. When the factory designs your flywheel, they take smoothness and other drivability factors into account and end up creating a heavier-than-necessary flywheel.
An Exedy flywheel still gives you great drivability, but the Exedy flywheel is made of lighter materials that take less engine power to accelerate. Your engine doesn't make more power and torque, but more power and torque gets to the wheels because your Exedy flywheel isn't soaking up as much of it as your stock flywheel did. Make sense?
Each Exedy flywheel is custom-machined from proprietary alloy metals and specially tuned to the vehicle upon which it is intended to be mounted. That way, your Exedy flywheel always gives you smooth shifting, scintillating acceleration, and steady idling characteristics that you'll love if you're a performance-minded driver. More importantly, you get back a handful of horsepower with an Exedy flywheel, which is what your goal should be with every modification you make"
Nengun
So are you's saying, when you replace your clutch, you dont need to get a billet fly wheel machined?
also, can you get a lightened or billet fly wheel, lightened more? (if it can handle high power, and ur engine isnt taking a bit off could make it snappier and still safe?)
Just a quick question guys,
I'm getting a Daikin heavy duty clutch installed, and have the option to get a lightweight flywheel. I've heard that I will loose torque if I do. Is this true? Will I notice?
yes. and your gearbox will make awsome ratteling gear noises up to about 2k loaded up
Depends what you think loosing torque is.
I found the car felt as if it had more torque especially in first and second when accelerating. I.e it felt as if it accelerated faster.
Launching the car required more rev's as it would bog down easier.
I was able to feel road inclines much more.
Free reving the motor was felt more crisp
Rev/gear matching on corner entry was much easier
High rpm gearchanges seemed easier, appeared to reduce the occasional missed gears and crunches.
Overall.. I quite liked my lightened flywheel. I wouldn't be going too light though. 5-5.5kg's is what I would be happy with.
I can't say I noticed a rattle down low but I did notice an increase in a labouring type feel at real low rpm. With the stock flywheel on there was no labouring vibration type feel at all. Not that you should be selecting a high gear and going WOT at 1000rpm anyway. :P
for me (having driven a few cars with lightened flys) the biggest drawback is the greater rev drop between gearchanges. that is the main negative in my eyes. if you can live with that, go for it.
This is the only negative i noticed to when fitting and orc flyhweel, u just gotta change a little faster. takes u about 2 gear changes to get used to
:P
    • had 4 weeks off over xmas and well did some stuff to the shed and BRZ, well short of is I don't work full time in supercars anymore as of yesterday.........
    • Did you get any down time over Christmas, or have you had any since to play with this? Or have you given up and are trying to get yourself a second hand V8SC instead?
    • A random thought I had just before I hit "Submit on this post". If brake fluid, in a container in my garage that has never been opened goes bad after 18 months, why can I leave it in my car for 24 months in an "unsealed container"... Secondly, some other digging, and brake fluid manufacturers seem to be saying 5 year shelf life... Me thinks there line on 18 months for an unsealed bottle is pretty much horse shit marketing spin. Kind of like how if you drive a car and don't run a turbo timer your turbo and motor will die horribly...   Where I started on this though... Someone (me) started down a bit of a rabbit hole, I don't quite have the proper equipment to do Equilibrium Reflux boiling per the proper test standards. I did a little digging on YouTube, and this was the first video I found on someone attempting to "just boil it". This video isn't overly scientific, as we don't have a known reference for his test either. Inaccuracy in his equipment could have him reaching the 460 to 470f boiling point range in reality. In the video, using a laser temp gun, he claims his Dot3 that's been open in his florida garage for over a year gets to about 420 to 430 fahrenheit (215 to 221c) Doing some googling, I located an MSDS for that specific oil, and from new, it claims a dry boiling point of 460 to 470f. Unfortunately they don't list a wet boiling point for us to see how far it degraded toward its "wet" point. While watching it I was thinking "I wonder what the flash point is..." turns out its only 480f for that specific brake fluid....   As for testing the oil's resistance, I might not be able to accurately do that unfortunately. Resistance level will be quite a LOT higher than my system can read I suspect based on some research. However, I might be able to do it by measuring the current when I apply a specific voltage. I won't have an actual water % value, but I'll have some values I can compare between the multitude of fluids. I'll run some vague calculations later and see if I should be able to read any reliable amount of current. These calcs will be based on some values I've found for other oils, and see how close I'll need my terminals together. From memory I can get down to 1pA accuracy on the DMM. I don't think my IOT Power Tester has any better resolution.
    • No, with a twin plate clutch flywheels and clutch pressure plate/friction disks go together. Only clutch where that isn't the case is the Uniclutch but they currently don't make a pull version for the Getrag R34, just some other cars. Personally the flywheel is as light as I'd want it to be. It already drops revs faster than I want to shift normally and I blip the throttle again to rev match on upshifts.
    • Are there any other lighter flywheels that can be used with nismo coppermix twinplate system? Id like to gave the revs pick up faster than oem
