i just went to have a look at the tapes, the security guy there couldn't get the bloody cabinet lock open! sounds dodgey, but i genuinely doubt he was involved. i will have to try again tomorrow morning as someone different will be on and hopefully have the correct set of keys. i will find out how these guys took the car, whether they hot wired it or just towed it off and update everyone.
thanks
Hey, if you want your car back, im more than happy to volunteer my car to set the f@*K heads up. I've got some mates that would be more than willing to help to. If they did fall for the bait and try it again, me and my mates will teach them a lesson and hopefully get ur car back. May sound pointless but its worth a shot. My names Simon, im in ferntree gully. I drive a 1993 R33 GTST, Gunmetal 2 door coupe. Feel free to call me on 0419 154 515. By the way, i have comprehensive insurance. lol. UP TO YOU.
Hey Simon, i really appreciate the offer, but i wouldn't wish this to happen to anyone. if something happened to your car, that would be really bad and i'd feel worse. i think they've been scoping out the place for a while as well, i've was parking in pretty much the same spot for a few months.
thanks again.
Hey im still more than happy to use my car as bait, it has 2 hidden kill switches in it, one for the ignition and the other for the fuel line, so even if they got in and could start it, it would stall in like 2 seconds cause the fuel would cut out, trust me i've forgotten bout it so many times. lol. Also sounds like you have more than a few people here willing to help out. Also remember that im knowingly putting my car at risk, so you would have nothing to feel bad about. Up to u.
Cheers.
Guesty.
i should be viewing the tapes on wed evening, the security boss is in wed, all these other ppl can't seem to help me. its not always security who man the place, in the day its mostly the national bus people.
thanks for the offer guesty, give me another wk, i'm thinking about taking it up.
ok, the security system is crap there. i was viewing it with the boss tonight, he admits its no good. the only really good one is pretty much the one which points at the shelter, maybe because there is more light there. we couldn't find the camera which pointed at my car, it was hard to use the system.
i think its time to move on. i dunno what car to get now, can't afford to spend too much.
thanks for all the help guys.
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
