Very nice indeed!
Looks pretty well modified from what I can see, what size turbo is that?
Yeah its coming , i don't think you ever stop looking for more power. The turbo is a T78 - 33D which is pretty cool, just had a screamer pipe fitted to the external waste. The noise is unlike anything but the biggest plus is that its started spitting big flames out the side on full boost.
Appreciate your comments
https://www.sau.com.au/forums/topic/63360-intro/#findComment-1193692
Very nice.  How big is the scene over there?
Hello Dude the Skyline scene is getting pretty big in the UK, the Jap scene in general is massive, scobbies, Mitsis and Civics are all over the place.
Theres a big modding mag Max Power which caters for the main stream boy racer but not alot other than our websites for the Skyline crew.
I'm always searching the net for other havens like this, you boyz have massive respect over here - i met Mario (exvitermini) while he was visiting Andy Barnes at Sumo Power. They just hit the 9's but it would appear that we've still got a lot to do to equal/beat some of your Drag monsters.
Thanks for your comments
https://www.sau.com.au/forums/topic/63360-intro/#findComment-1193704
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
