just checking my average fuel consumption... i get maybe 300km to a tank (well full to empty which seems to be about 50L).. so about 6km/L.
mods i have are as follows...
microtech LT-12 ECU,
arc front mount intercooler,
hks boost guage + turbo timer,
twin plate clutch,
open air pod,
turbosmart bov,
3 1/2" straight through exhaust 4" tip.
dyno shows 200rwkW
when i bought the car i was told the ecu had just had a stock fuel map put on it due to lack of time, but it runs really rich.. so much that the back of my car has a black dusting on it less than a week after washing it, and you can smell the fuel wafting past as you stop at intersections and whatnot...
im guessing this isnt all too good fuel consumption, so getting the ecu remapped would be the only solution?
if so.. who/what/when/how much $$$ would i be looking at to get this rectified.
cheers in advance :P
https://www.sau.com.au/forums/topic/63366-fuel-consumption/
Im told Microtech's don't have closed loop, so even when cruising you would be using shitloads of fuel, if so then that's part of your problem
Maybe it's they way you drive :P when I first got my car a caned it and wondered why I was getting such crap economy. Months later when I drove much more sedately and was getting better economy, I realised why.
https://www.sau.com.au/forums/topic/63366-fuel-consumption/#findComment-1192427
its actually stayed the same wether i thrash it or not (well.. mostly anyway)
there is a serious flat spot at the start of first gear, dumps a shitload of fuel, then takes off... can see it more prominently when you go to do a quick takeoff.. jumps off the line, then dies, then pick up again... thats where most of my fuel seems to be going.. moving from a stop..
https://www.sau.com.au/forums/topic/63366-fuel-consumption/#findComment-1192453
you need to find out if the microtech has closed loop control ability
if it does you should check your o2 sensor as it is what the closed loop system runs off
closed loop is where the ecu switches from map to o2 sensor after a stable throddle position has been reached(cruising), then basically tunes to a ~14:1a/f ratio while steady throddle position remains.
hope that makes sence
pete
https://www.sau.com.au/forums/topic/63366-fuel-consumption/#findComment-1194403
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
