just got my car back from compliance and all that and the stereo wont turn on. when i test drove the car the stereo worked...does anyone know why it might have stopped? it's on of the stock head units for the '95 R33 GTS-T. it's got a single DIN with a tape that look like the main unit...then one above it with a cd cartridge that holds 3 cds. it doesn't look like it's getting any power at all...any ideas.
cheers mark,
https://www.sau.com.au/forums/topic/63370-stereo-probz/
if you're lucky they could have shorted you and blown a fuse
if you're unlucky they may have managed to disconnect a valable wire such as your main, remote or earth to the head unit:) will be fun to find, when in doubt - get out your multimeter and start at the back of hte head unit, if its recieving full power on the yellow wire, a signal on the red when your key is on ACC etc, and the earth is strong. then i would be asking your compliancers to replace what they blew up
not that i can see how they managed that:)
https://www.sau.com.au/forums/topic/63370-stereo-probz/#findComment-1192723
well i checked the fuse box under the dash on the drivers side...a friend who knows a bit of japanese said he thought it was the one on the right 5 up from the bottom. it was a 10A fuse. looked fine to me, replaced it and nothing different. what should my next move be...?
https://www.sau.com.au/forums/topic/63370-stereo-probz/#findComment-1195807
Did the radio pick up stations when you test drove it? During compliance they fit a fm band expander thing so you can pick up aussie stations. They may have stuffed up the installation of this, take the stereo out and have a look. It will look like a box that is plugged in between the aerial and the head unit.
https://www.sau.com.au/forums/topic/63370-stereo-probz/#findComment-1197132
