Hi
My name is randall and I own a 1994 Skyline GTS-T (RB25DET) .I live in The Netherlands and there are less than 10 skylines in this country, thats why I'm reverting to Australian help..
I've pulled the car apart completely and going to have it painted and then rebuild it completely.
Now I've come to my engine, disassembled it and building it again now, installing arias 87mm pistons, crower rods, new bearings, grex oil pump,N1 waterpump etc.
Cilinder head will receive flowjob with greddy intake manifold tomei springs (want to up the rpm's) and in/ex cams 256in/264ex.
Blitz front mount intercooler, nismo 740cc injectors, Z32 MAF, Apexi power FC. PWR Radiator.HKS full race exhaust, cat replaced by straight pipe.
Now my question is; (and yes I've used search) for approx. 450-500 rwhp can I use the greddy TD06SH-25G 10cm full turbine kit?
My demands are top mount manifold, not to laggy( want to drift) boost coming in at 3000..... but am afraid with an 8cm turbine housing the turbo will choke at higher rpms.
I am a huge fan of the Greddy kit but want to hear first hand experience , since all the skylines over here are bone stock...............
Thanks
https://www.sau.com.au/forums/topic/63384-trust-kit/
thanks, read all 3 pages of data and comparisons and trying to make a solid decision based on my needs for the car...read that boost starts at approx 4000 rpm, which in my opinion could be realized earlier by a quick spooling BB turbo with a smaller turbine A/R.
Can someone tell me if a greddy T78/T88 manifold flange is similar to a T4 garret flange? I believe so.
So if I were to buy a trust T78 manifold for the Rb20DET and fit it to my RB25DET and add a T4 BB turbo with a turbine A/R size of around .70-.80 and a compressor big enough to realize 450-500 whp, would that work?
https://www.sau.com.au/forums/topic/63384-trust-kit/#findComment-1192639
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
