Hello
As per usual I have bought something then the car has turned up with it :( I get my car back monday and it already has good dampers in it, so no point in changing them.
OK, They have not been on the car, but I will be slightly flexible in price, these are the best condition pre-loved shocks I have seen in my life. I wouldn't have bought dodgy crap and I don't sell it
I got no tools with it but I purchased a universal adjuster height adjust them. at 40 extra cost to me. this is included, as for the damper adjustment you can just use a suitable size alan key :rofl:. They are only 1 month old in terms of USEAGE and less then 4000km's travelled on the car I was told. they look it!
PRICE is $1400.00 + shipping, I'm in sydney so if anyone wants to pick them up I can meet you somewhere.
These have just been advertised in SPEED magazine, price new from a shop is
$3250.00
ABSOLUTE BARGAIN!!!!!!!!!!!!!
mark (PM for PHOTO's or post here, preferred phone contact for questions)
0411113875
Type NA Damper
Type NA for solid and sharp handlingThe type NA damper can be used from the street to the circuit with 16 levels (clickable) expansion and contraction adjustable mechanism. This damper is for those who want to enjoy the ultimate driving in various situations.
THE TEIN OFFER Suspension tuning is a must item for people who pursue the joy of driving. You cannot start to talk about the enjoyment of perfect control of your car without suspension tuning. However, there is a tendency to see it as something limited to people who want to drive in circuits or rush through mountain roads, something which is at the detriment of riding comfort. Most people either give up or don't want to go to extremes.However, this set us thinking. Do you really need to give up comfort for a sporty ride? Can't you get better footwork from your car with more ease? So this is what TEIN offers. Low-down styling with sporty handling, but balanced with comfort.TEIN TYPE NR/NA DAMPER KIT gives you the opportunity to improve your footwork, just as you would change your tires or wheels.
TUNING OVERVIEW TYPE NA/NR DAMPER KIT
is based on styling, comfort and well balance. Everything has been reviewed in order to create a new footwork at levels which could not be accomplished with the low down spring or low down spring and sports shock absorber combination. The biggest feature of this damper is that even though it achieves the low down styling through short case, we created stroke, damping effect and spring rate for the street from scratch. In normal short stroke structure sports shock absorbers, by shortening the stroke, the damping effect must be adjusted in order to absorb the impact from the roads, and leads to bumpy and uncomfortable rides. TYPE NR/NA DAMPER KIT expanded the case diameter at the same time of short casing. It allowed for improvement of 130% capacity over normal and maximum stroke. This led to stabilizing the damping effect and can bring sporty handling with low-down form with a balanced comfortable ride without needless adjustment of the spring rate and damping effect.In addtion, it is also allows for changing tires and wheel sizes, an ever popular option. Our product will adjust to any weight changes and changes in performance which comes from changing tire and wheel sizes.Normal roads are different from the circuit with mixed road surfaces and conditions. With the prices for screw type height adjusting shock absorbers becoming this low, it is possible for original type shock absorbers to be free of going extremely in the direction of short strokes and sport setting. The TYPE NR/NA DAMPER brings to you the right setting for road conditions, with both comfort and stability.
ASSURING SHORT STROKE AND MAXIMUM STROKE
Generally, sports shocks tend towards emphasizing their short strokes. By shortening the stroke, they need more damping effect, leading to deteriotion of riding comfort. Our TYPE NA/NR damper achieves short casing, but with maximum stroke. In addition, we have been able to achieve 130% capacity over normal for damping effect, allowing for stability. We bring to you, sporty handling without having to overly increase damping effect, making for a balance of comfort and sophistication.
WELL BALANCED TUNING
We offer height adjustment, stroke, spring rate, damping effect setting which are optimal to each model type. Just like there are different types of dress-up methods for sedans, saloons and sport cars, we offer a variety of choices for your car's footwork. Through this, our TYPE NR/NA dmaper kit is available to a wide range of users - from the comfort oriented to the sports oriented.
COMPATIBLE WITH LOW DOWN FORMS AND INCH UP TIRES TEIN NA/NR damper allows for changing tires and wheel sizes, an ever popular option. Our product will adjust to any weight changes and changes in performance which comes from changing tire and wheel sizes.
https://www.sau.com.au/forums/topic/63411-tein-na-coilovers-bargain/
My mechanic hasn't had time with him working soley on my car.
but after speaking to a place in Vic they said that they wouldn't be much thicker then the std shocks if at all. not too sure on it.
They have from memory 4 height settings, and 16 damper adjustment settings, these are awesome,
anyone wanting pics put there email here
thanks heaps
mark
0411113875
My mechanic calld me this morning and Said they are 12.5mm pistons on all 4
I have pics but no where to host them so if you want to see them PM me or post here. could be flexible on price so call me to discuss
if someone wants to host photo for me that would be fantastic!
mark
0411113875
    • You’re all still going on about track cars, he has said multiple times doesn’t intend to take it to the track,  just stick to what was said at the beginning and do the pump and ecu, it’ll get you enough for 230kw at the wheels and has enough poke to be fun for what you want it for
    • All of that is absolutely true. At any time in the history of these turbos the lottery has always been that it could die at stock boost treated exactly as the factory intended, or it could die when pushed to 10, or 12, or 14, or 16 psi, after a short time, or a longer time, or it could last seemingly forever. You have the combination of all the possible statistical (probably) normal distributions of manufacturing tolerances and quality outcomes, on top of the statistical distributions of failure modes (which might be normal, but are probably biased, like Poisson distributions). You get the lucky turbo and you can beat on it for years. You get the really unlucky turbo and it will crap itself as it rolls out of the factory gate. And every possibility in between. But you can definitely still kill the lucky turbo. It's just that most people didn't try, once they knew they really shouldn't try.
    • Maybe I have Stockholm syndrome but working on an M2 isn't that hard. Getting parts cheaply and quickly is hard, but getting parts same day isn't necessarily hard if you're willing to pay way too much for it at local dealers. There's a lot going on, you need to have a build of ISTA on a laptop and the right cable, if you don't have the mindset of "do it exactly right or not at all" you will probably start seeing cascading failures. Skylines are a little more tolerant in that regard. The car doesn't potentially trash itself if you bought the wrong oil filter like a BMW would. Or trash the entire cylinder head and potentially spin a bearing because someone took the anti-drainback valve out of the plastic oil filter cap. An M2 will also do just fine on track, zero oil starvation concerns, factory brakes are great if you change the pads for a high temp compound + flush with track-ready fluid.
    • The "ideal/formula" that used to be touted was death of the turbo is going to be caused by a combination of 3 things. Heat Speed of turbo (boost level you're pushing) Time   Basically, you can get away with high heat and high boost for short periods. But start doing long hard pulls, or circuit driving etc, and now you've increased time as well which will shred things. From memory when Adrian was drag racing he was running 17psi, on a stock turbo, and running insane speeds. But he also had other additives helping in the setup too. Some people have success at 14psi for a while, while others due to pushing the cars hard for long periods opt down to lower temps. But also, generate a lot of heat (let's say bad tune), for a long time, and you'll be okay, until you try to spin that little guy up slightly. It's the one advantage of dumping a lot of fuel in, you'll be reducing EGT a bit and helping with the heat portion of the above 3 areas.   And these days, stock turbos are that old that there's the possibility of just outright failures due to material age. I'm not shocked that even when used in factory spec that a stock turbo fails when 30 years old. It's a worn out "precision" "balanced" performance item, that's likely no longer precise, or well balanced
    • this... hence I said what I said previously, SMSP nights you see mainly Hondas, Evos, A90s, F80x and the odd VW. The 5 or 6 times I went, I only saw 1x R32 GT-R, and other than that I was the only one in a shit box Skyline.
