**UPDATE! I have uploaded a few photos further down the thread***
TRUST dual pillar pod mounts to suit R32 GTS-t $100
Greddy Profec B spec 2 $400
DEFI link control unit 2 *SOLD*
DEFI link white faced 60mm Boost pressure gauge *SOLD*
DEFI link white faced 60mm Fuel pressure gauge $200
DEFI link white faced 60mm Oil pressure gauge *SOLD
DEFI link white faced 60mm Water temp gauge *SOLD*
TEIN type HE fully adjustable coil overs to suit R32 GTS-t $1200
CUSCO Type OS front strut brace to suit R32 GTS-t (brand new) *SOLD*
CUSCO Type OS rear strut brace to suit R32 GTS-t (brand new) *SOLD*
TRUST R-SPL front mount intercooler KIT to suit R32 GTS-t (brand new) $1300
HKS GT2535 T3 flange $1800
Custom stainless 3" one piece front/dump pipe to suit R32 GTS-t (brand new) *SOLD*
R32 GTS-t wilkinson adjustable front top arm bushes (brand new) $180
[email protected]
Cooler has never been driven with, I had it fitted to a project car which I have now changed my mind to complete. Comes with polished stainless piping and greddy silicon joints. Not a single fin is bent. I also have the purchase reciept for it which is quite scary.
To give you an idea what the gauges look like, here is the boost (which is sold) one (i'll take some pics of the oil/water defi's when i get home).
    • Update for the sake of closure   Ended up getting the intercooler piping all sorted, new plugs and yellow jacket coils, and she was idling mint until it warmed up while I was bleeding the cooling system. Found the misfire to be localised to cyl 3 by unplugging coilpacks, ran a compression test, that checked out, then decided to get a mate to check if that spark plug was firing out of the motor. Upon cranking it over, with the injectors disconnected, the car actually fired and ran on a couple cylinders and heaps of fuel came out the top of cyl 3 I'd say that injector's either spraying incorrectly or spraying far too much, which is fine as I'm planning on replacing them anyway I'm planning on making about 250kW on flex fuel, and have a set of 1000cc injectors from ozautosport, obviously overkill but I'm planning on building the motor and running more boost further down the line, do you reckon they'd be too big for a smooth idle on 98? Thanks for the replies gents, much appreciated
    • I'm confused. You said you want to "remove the clear coat from most panels" but it sounds like you are actually doing a full respray? Few random things to add -  If you chase the blistered paint with 120 grit, I can almost guarantee you'll chase it down to bare metal (that's fine). But if you paint the car from here, you'll have nice little indents where ever the blistered paint was. The new paint won't magically level out the low areas, you need to fill them. Which leads me to the main point I wanted to add, make sure the whole car is flat before you paint it. All those areas with blistered paint you sanded out, make sure to fill them and triple check they are flat with a block guide coat. I'd also check the whole car is flat with a large block and guide coat but yeah up to you if you want to go that far.
    • 300hp (225kw) is barely outside the standard turbo's range with a bit of extra boost in it (200ish). If you are going to change the turbo you should aim for 250-300kw (330-400hp) to make the expense worthwhile
    • A couple of things, firstly omg that turbo is expensive! $3,000 USD for dinosaur technology is robbery. You could buy a G series turbo and have a good amount of change instead.  If you want a good budget option, have a look here - https://hypergearturbos.com/product/rb25dethighflow/ If you are keen to spend more, have look at the modern turbos, Garrett G series, Borgwarner EFR, etc. Have a look at the RB25 dyno results thread for inspiration.  If you upgrade your turbo to something that will support the 300hp you want and only "probably" have Haltech ECU, your car will only "probably" run. Actually, no it won't run. You are going to need the ECU and injectors at the time you do the turbo upgrade.  No thoughts on "this much boost" as you didn't say how much boost that actually is. Having said that, plenty of unopened RB25's making even more power then what you are chasing.
