I have recently purchased a 1990 R32 GTR from japan. After reading countless material, forum threads, friends advise etc im some what in the least confused as a horny prick in a brothal.
I brought the car for a fairly good price at it has done suposedly about 60,000 k's.
I take delivery of the car next week, so in the mean time I have been wondering what mods I can do to it and perhaps do some forwrad planning as to expected cost's, part sourcing and to try and find a mech that wont do crap workmanship on my car nor talk bullshit and has exp to back him up.
I dont want my car to be some over kill machine nor do I want to lose respect by being beating by some homo in a v8 commodore or a WRX.
So taking that into consideration these are my questions.....
What mods shall I do first? eg and in sequence?
eg bosh fuel pump then injectors then ecu then etc etc......
best place to source parts new and second hand any good mech's in perth that deal with skylines etc only?
Do brand names count? as just becuase its trustor HKS does that make it better? also ecu's
https://www.sau.com.au/forums/topic/63445-r32-gtr-where-to-start/
On the mechanical side of things when she arrives get a full service done and get it looked over by a workshop there that deals with these cars . I'd be also doing a compression test and organising a dyno run just to see what the tune is like .
If everything is ok and you have a established that you have a healthy GTR then when it comes to mod's ( don't know what mods your car has already) I would be starting with an after market exhuast nice front pipe and if you can afford the labour a decent set of dump pipes (r32 ones are restrictive) . Next step would be ECU something like a power FC which is easy to install there are a fair few ppl who are good at tuning them these days . I would also advise an electronic boost controller to keep the boost to a sane 1bar if you are running the std turbo's. At higher boost levels the turbo blades can leave the shafts and cause you all sorts of trouble .
Get the car straight to a decent workshop.. get them to take a couple of hours to look at it, do the basics, and let you know what you're up for in terms of further problems/repairs. Odds are it'll be time to get the wallet out... its just the way old GT-Rs are..
A place like Hyperdrive can sort you out
well you can do the most basic first, which are full exhaust, pods filters, boost controller. those few things hsould keep ya happy for a while.
but as said above, get the car checked out and fuully serviced. i drove my car home from freo back in decemeber and havnt driven it since.
Most of the engine's out as well as all the pipiing, cause i wanna give everything a good clean and repaint. im also going to change all the belts, seals and fluids.
steve
60,000km..in an 89 gtr you bought for a good price.rofl.
Mate I hate to burst your bubble but a genuine one would go for more in Japan than the on the road price here in WA.
realistically expect to spend $1K for a major service which includes all oils changed to quality synthetic products and that is motor, gearbox, front and rear diff and transfer case, new timing belt, new water pump , plugs, fuel filter and brake fluid flush.check and report on brakes, d/shaft boots etc.
If the car has any more than 2 d/shaft boots gone or been replaced recently, I suspect closer to 100,000km
At the same time we comp test/cylinder leak test it as see whether it is worthwhile continuing or advising you to get your wallet ready for a big hit..
Cheers
Ken
I've just spent almost 5K on servicing and mod fitting/compliance
so start saving mate, plus my mods cost 6K over the last few months and they are all suspension, braking, replacement parts for old ones, Blitz dual EBC excl.
had the tensioner pulleys and other stuff replaced, trying to make it more reliable. braided brakes hoses.....thinks like that. more of a circuit person then drag
mark
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
