thanks guys, I got it checked today... there seems to be fuel coming from the side of it..I don't know if that's fixable but the guy advised me to get it tested first...he thinks I may have to replace the injector, I'll pull it out soon and give it to them...will know more soon.
https://www.sau.com.au/forums/topic/63455-leaky-injector/#findComment-1194828
I had a leaky injector 3 days after I first got my baby. I took it to DynoTune and they had it for 4 days, it turned out to be a bodgy o-ring and Nissan sent them a set of new ones......except...... they sent one wrong one out of the six, but they didn't work this out til I'd gone out and got another set of injectors......
So if you need a stock r32 rb26 injector just pm me.
https://www.sau.com.au/forums/topic/63455-leaky-injector/#findComment-1195062
pm sent
https://www.sau.com.au/forums/topic/63455-leaky-injector/#findComment-1195087
thanks for the reply mjfawke,  Is there anything I need to know before removing them? I don't want to damage it any further....can I just take the fuel rail off, then twist the injector anticlockwise or is there a special way to take them off?
Nah - twist and pull, the O-ring will stay on the end of the injector. The manifold seals will probably stay with the manifold, so be careful getting them out (scribe/small screwdriver etc) - you don't want a leak.
https://www.sau.com.au/forums/topic/63455-leaky-injector/#findComment-1195309
ok... so today I decided to pull the injectors out and i think i've found the problem, on the front of the injector there's a green plastic bit that looks sort of like a nozle... along the side of that is this crack probably a bit smaller than 1cm... it doesn't reach the main body of the injector though, other than that the rest of the injector looks pretty good and the O-rings look ok....now im just wondering if that plastic bit is replaceable or not... gotta wait till monday i guess :D
https://www.sau.com.au/forums/topic/63455-leaky-injector/#findComment-1196019
pm sent
Hey there GM,
Sorry I have got back to you earlier but I had a very busy weekend and haven't had a chance to check the forums. I've PM'ed you with my mobile number, just give me a buzz when you get it. How many injectors were you after?
Cheers,
Brad
https://www.sau.com.au/forums/topic/63455-leaky-injector/#findComment-1198167
can anyone suggest someone to test my injector system as I dont think they are firing and I dont have a tester (light).
Plus anyone wont to finish getting my turbos off? what a shit of a job! they are down to the oil lines and there is like 4 on each turbo. they are all thats holding them in.
https://www.sau.com.au/forums/topic/63455-leaky-injector/#findComment-1198272
1. Try Geoff at Capital Injector Cleaning - see Jayce's post here for the number. He's been pretty good so far.
2. Sorry no. Prob would've if you'd have sold me that gear knob. LOL J/K.
https://www.sau.com.au/forums/topic/63455-leaky-injector/#findComment-1198371
finally got the injectors checked...and there pretty much screwed..well 2 of them anyway, it's all sorted now, thanks oz32 for the injectors, there working good by the way..no problems :mad:
Hey stirlo, I got the injectors checked at tugg car care... I don't know if there any good as they just quickly checked them and said they couldn't be fixed.
not too sure about the turbos but isn't there two bolts holding each line in that you just need to undo? I can give ya a hand..don't know how much help I'll be though :confused:
https://www.sau.com.au/forums/topic/63455-leaky-injector/#findComment-1200426
finally got the injectors checked...and there pretty much screwed..well 2 of them anyway' date=' it's all sorted now, thanks oz32 for the injectors, there working good by the way..no problems :(
No probs GM :) Glad to have been able to help!! and great to hear that you're back on the road!
Cheers,
Brad
https://www.sau.com.au/forums/topic/63455-leaky-injector/#findComment-1201151
    • Oh, that's grim. Something bad has been happening there.
    • Put an endoscope down the hole and saw this. Not quite all around the bore but a good 60% at least. Chin to the chest and towards further disappointments I guess.
    • 2 does "sort of" applies, maybe......but looking at what parts would be needed for the swap to get engineered, registered, and insured, and basically that's everything under the car, the modifications the make it legal would be problematic and horrendously expensive, all for a street car that just cruises around and hits a few twisty roads on the weekends Also, from looking at the NSW rules and Regs, with all modifications that is required just to make the car safe and not twist itself to pieces, and then actually get registered for street use, may still be impossible nowadays As for 1, when you add in a fresh engine, fresh transmission, rear cradle and diff, tailshaft, suspension, brakes, cooling, and all the other fabrication required, your probably looking at up to $100k to do it right, all for a 20 year old MX5 that is over engineered and you would never be able to actually use the power it has on the street, much like your beastie, which I love, but you actually track that thing and can use all of its powers in anger, in a safe environment  Hell, the old Bogan Cruise Ship had more power than I could use on the street, and in hindsight, I went a bit silly on that thing, it didn't really need the 500hp it had for what I actually used the car for, it was fun, but basically unusable on the street if you value your licence  As for cams, yeah, I'll probably book it in for them to get installed and tuned soonish, like next month after MX5 Mania are back at work....... and yes, I've already sent a email to bin the turbo quote and quote instead to install cams and a new Fluidampr balancer that will suit the 2.5 better than the OEM 2.0 balancer that is swapped over for the 2.5 install, as the balancer needs to get pulled to time the cams it's a while your in there sort of thing I did think a bit about flex fuel for a laugh, but being na, and no where really around locally anymore to get E85, I've binned that idea, so no sweet sweet corn smells are set for the car I wish E85 was more of a standard fuel, it's better for the environment, better for tuning, plus that sweet sweet smell we all love As for fitting in the family, that's not needed, as everyone in the family already owns a car that can seat 5 humans comfortably enough, the MX5 is "my toy" As for buying a car that is already built, nah, I would rather pick and choose my parts, I enjoy the process, and in the big picture, the additional cost is well worth the enjoyment, and the occasional frustration, I get out of doing it, albeit with other people spinning the spanners, and me, just paying the invoice 🤣
    • Excuse me, but 2) does apply 1) Would also apply if you consider how much is spent in the alternatives. Also there's the option of 3), buy one pre-built that you can put your family in (it's me, it's my car)   That said, I went on a ~500km drive the other day. I didn't use anything more adventurous than 3rd/4th gear at about ~3000RPM and 50% throttle and I was going as fast as anyone has any sense doing on a public road, with enough grip to the point where I didn't want to go any faster. I was obviously under the limit of the current car etc etc. MX5 with 2.5 N/A to achieve the same speed would be more fun for any road scenario. Maybe consider cams. I wouldn't boost it. The use case is just not there and it won't actually make the car more enjoyable unless you really do plan on wringing gears from 1st to 3rd (at least) at 100% WOT on a public road to 150+kmh.
    • Great if: 1. You had all of the money for everything else that is required  2. Lived in a country where you could actually do this and drive it legally on the road Sadly, neither applies to me As for the turbo, I am having second thoughts, mainly for engineering/registration legality reasons and insurance  Not saying I've finished doing stupid things that I probably should do to the MX5, but boost, and V8 engine swaps isn't on the cards Strange, but true
