Similiar to what happened to my sisters VL after the flush.
Only difference was before the flush it wasn't overheating, after it was. :cheers:
I pulled the radiator out and when reverse flushing with compressed air and water I had what felt like bark chip covering my hand. It was massive bits of scale that had blocked the core. :(
That may be the case. It might not be the head but how pissed would you be if you spent all that money doing all this other 5hit and then find out it was coz a fake mechanic couldn't do a simple test.
How does he know it's not. Has he got Xray vision or something. A dye test will pick up the smallest leak that won't even cause your car to overheat.
Well anyway, I'm done with the advise. If you choose to ignore it, that's your choice. Like I said before, it may not be the head. I hope it isn't. I hope it's something simple to fix because I have gone through all of it hundreds of times. I just believe that it is best to cover all bases so that you rule out all possibilities. To say that it is not a particular problem without performing the tests to prove it is just foolish. I really hope they do the right thing by you.
Well i like to say 3LIT3 FORS3 WAS right.... and i should of done he sed...!!
it was a blown head in my engine !!! ****en bullshit !!!!!!!!!
so now i got a quote from ADD racing to get it done for 1200
wat do u guys reckon of that price??? any places in brisbane that will do it cheaper ???
and what does it inovole wen changing a new head ?????? pullin the engine out ???
You would get change from $800 if you did it yourself. Plus without knowing the condition of the head it is impossible to give an accurate quote as if the head is bent it will cost $600 to get a full head service and straightened. Now I'm sure even if you got the $450 VRS set for free, you would still not get away with $800.
Worst case scenario is:
Full head service $600
VRS $450 (assuming you can buy the VRS seperate from the full kit which is $600)
Labour - 9 hrs - $500
Oil and filter change - $50
Coolant - $30
Timing Belt - $80
Plus you have to account for broken exhaust studs, hylomar spray and any vacuum lines or hose clamps that may break while doing the job.
Total worst case scenario is: $1730 approx
If you can get a second hand head that is already straight or the head you have is still straight, the price would then drop to $1250 plus the cost of the second hand head if so required.
If you do it yourself you would save the $500 labour so then it would drop to $750 for a straight head and $1230 for a bent one.
