drifting in perth??
Black-Beast
 Share
  • Replies 47
Or just rock up to ur nearest tyre shop and ask to take their cruddy old 16s off their hands :rofl:
Also the Tenagah Motorsport Drift day in Collie has been pushed back to the 17th due to trackwork going on - in case anyone hear was interested in attending.
-Lozzle
In keeping with our commitment in promoting and encouraging all levels of motorsport, I have an invitation to anyone interested in joining us in a Drift Training day at Collie on Sunday the 3rd of April. Tenagah Motorsports is holding the training day in association with AFARCC.
At this stage there will be 4 instructors available on the day and I have 40 spots available for people who are wanting to learn. The schedule for the day will be along these lines;
0800 Scrutineering Opens
0930 Compulsory Driver Briefing
0950 Instructors Lesson
1000 Track Opens
1230 Lunch (Entertainment by Instructors)
1300 Track Reopens
1700 Track Closes
Cost is $50 for AFARCC members and $70 for non members.
To confirm your spot, payment is to be made directly to Tenagah Motorsports. If you do have any questions please contact myself at the shop or Jimmah via email at [email protected].
Cheers, Abdus.
However!
We were informed yesterday that MSW are having a track maintenance weekend
on the 2/3 of April.
The AFARCC driver training day is now on the 16th April and the Tenagah Drift day on the 17th.
Hope this doesnt inconvenience anybody, but this one was totally out of our
hands.
BB: PM 'Tenagah Motorsport' on the Silviawa forums or email jimmah (email above). There's a few spots left so snap one up.
-Lozzle
 Share
    • Thanks to @V35_Paul there is an oem stereo available on gumtree, but the fascia is slightly different. It has a flip up screen as opposed to my pop up screen. Am I able to disconnect the radio/cd player from the fascia to use it on mine?
    • Had to google what a quart is lol.. so rough as guts a litre. That's a bit excessive, also what oil weight are you running? The whole steam cleaning idea isn't too far fetched either. Maybe as you suggested, turn off the WMI (assuming your Kebabtech pulls timing, boost, etc.) and run it for a bit and see if there are any noticeable changes in spark plug colouring.
    • Pretty simple question. I was about to put the transmission back in and thought I pretty much had it lined up when I noticed it seems like the pressure plate isn't flat. I was pretty careful when undoing the bolts both during initial disassembly for cleaning and when torquing them up for installation so this is pretty discouraging. I'm not sure if I accidentally bumped the pressure plate with the input shaft and bent it somehow or if it just showed up this way. Is it possible that there's just something obvious I'm not doing correctly? I'm pretty sure I was extremely careful to make sure the friction discs were seated correctly in the hub, everything lined up, flywheel torqued according to sequence, the little springs all sitting correctly in their seats, etc.  What's the play here? Do I jump straight to a new pressure plate?
    • OK. I can see that being the case. But if you live in the land of "only switching between 4.08, 4.11, 4.36" like most Skyliners, then you never encounter it. Now I perhaps understand why the crownwheel is thicker on some of the smaller numerical ratio diffs. The two stubs being the same (unequal) lengths and just swapped side to side between the different cases is a new one to me. I'm hating Nissan R200s more than ever now.
    • Reason I say this is I have seen broken ones, in drift, drag and even behind a stock Z. I do appreciate most of the time its the synchro's that go.   Trouble with quoting HP is it doesn't really say how strong the box is.  I've not seen many CD00X box's make it past a mid 9(150mph) I have seen about a stock R33 RB25 box's run a 9 too, they all go boom at some point though.   Another clue is they make gearsets for CD00X box's too, wouldn't be a market if they didn't break or have a limit people are going past.   I totally agree it is a strong box, just have to weigh up the true total cost of the conversion vs rebuilding with a good gearset.
