drifting in perth??
Black-Beast
 Share
drifting doesnt need mods, the more mods the easyer it becomes to drift (my thread anywayz) for example to get a stocky r33 sideways (yes it is very possable and not just power-side) it is abit hard due to weight etc etc but if it had like a 400ps and a few sups mods i belived it would be soo much easyer.
drifting is more skill than anything i belived, if in the d1 a 175ps ae86 can out drift a 450ps s15, and a r34 4dr, soarer and chaser which all weight alot can also drift and place in the 10top what can i say.
ohh yeah turn wheels in slightly = camber
what does camber mean ?
and what about sway bars ? are they needed? i always thought the body would start to bend n stuff after lots of drifting without these bars, or am i wrong?
  • Replies 47
Denver said it - there's bulk interest here in Perth for drifting - just not the places to do it. Collie is the only place thus far and it's undergoing a transformation which has put off any events (practices & comps).
-Lozzle
Static camber (as in camber while stationary) is the angle of the wheel to the ground. For example zero camber gives complete and even contact of the tyre with the ground so that it isn't biased on any particular side of the tyre and hence gives more traction.
People often talk up about negative camber so that it compensates for the turning forces in the car so that under heavy turning the car can be as close to zero camber as possible. Too much negative camber however and it will eat away at your tyres quicker than you can say F***, this is why most modded street cars go for about negative 1 degree of camber and race cars go for about negative 2-3 degrees.
Sway bars bars also known as anti-roll bars help the weight transition when cornering. If the bars didnt exist, if you turned really quickly all the weight of the car would move very quickly to one particular side of the car. Upgrading sway bars makes the car much stiffer and puts more even loads on both sides of the car during fast cornering. Also the particular stiffness can affect whether the car understeers or oversteers by nature. This is dependant on the different stiffness of the rear and front sway bars.
:P
:P
Wow nice answer man, so in other words get sway bars for better corning because the weight is distributed evenly ?
So the sway bars dont protect your car body from bendin? is it even possible for a car body to start bending or something after tonnes of drifting ? like say over a couple years of drifting every now n then.
The car will probably start bending after time but I imagine (not quite 100%) the sway bar would bend before any other damage would be done. A stiffer sway means that when a car is cornering, more force is distributed onto the inside wheel rather than dumping it all on the outside tyre. I imagine that having stiffer sway bars elimanates the need for going out and spending heaps on really stiff drift coilovers to get basically the same result. That way the body wont flex as much and softer springs can be used for day to day driving. However if you avoid using coilovers completely you start to worry about centre of gravity etc. etc.
c-red is aimed at mainly pro's. its only for 3 hours on a friday night so they dont wanna have to stop all the time to dig pplz out of the sand. which is fair enough.
collie would be the good idea :P
there are lots of places to street drift.. but it shouldnt be done... unless u like to bend over and take it whilst u see ur car leave on a trailer :)
-pie
Hell yeah, someone should make one on a property out of the metro. I would be going there all the time. Well when you think about it. Theres basically nowhere you can take your car to go drifting (legally) or to go and do burnouts other than the drags and the occassional drift meeting at some tracks. I would be spending a bit of time there.
and use Khumo tyres, don't need much else
 Share
    • For students aiming for top grades, our Best Assignment Help offers the perfect solution. Our team of experienced writers delivers meticulously crafted assignments that meet university standards. We prioritize originality, timely delivery, and round-the-clock support to ensure your academic achievements.
    • I should clarify that the previous owner put the wheels on, so Im not entirely sure what he bought. I was searching the Rota page and found these two as the only matches. It did not occur to me that perhaps they sell these wheels with different offsets. I guess the best way to solve this is to take the wheels off and measure them from the inside to be sure.
    • The offset doesn't really have anything to do with dish directly. I mean it kind of does but it also doesn't, it's only tangenial. The offset is purely how much offset (get it) the mounting face is from the CENTER of the width of the rim. I.e, the mounting face would be directly in the middle of the 9.5inches if it was a 18x9.5 ET0 rim. Given it is a +12 rim, the mounting face is 12mm further away from the center (to the outside of the car). Your fronts are +30, so the mounting face is 30mm further away from the center (to the outside of the car). I would wager this doesn't look right, because most skylines generally have the same with guards front to back. So I'd think your fronts look significantly more sunken in than your rears. I'd wager by about 18mm, or so.
    • My '96 r33 Skyline has Rota GTR, 18 x 9.5 inch, ET30 on the front and Rota GTR-D, 18 x 9.5 inch, ET12 on the rear. (Put on by previous owner) The 12mm offset is throwing me for a loop. Is it due to the "deep dish" design of the wheel that the offset it so low? Or is it actually that low on the rear normally? If I were buying a set of new wheels, could I put 30mm offsets on the rear and reasonably expect them to fit? I have GTR Brembos and 370Z rotors (355mm/350mm) if it matters. Thank you.
    • here is the video, again really hard to hear but in person its very loud 20240703_175734.mp4
