Check to see the the motor is plugged in. It is located closer to the rear of the vehicle on the driver's side. It has Sumitomo on it (manufacturers).
Some people disconnect it to avoid problems or to solve problems they are having.
https://www.sau.com.au/forums/topic/63569-hicas~help/#findComment-1213232
the unit is still there but it looks like it has been altered.. it has a small TOMEI black unit piggy-backed on the hicas unit.
what does this mean??
better or worse?
suspension has been changed to a full trust suspension and bushes the rod holing the bushes...and also a cusco tower brace with another brace that is holding the brake master cylinder.
what does this all mean??? that the car was used for circuit? / drag/ drift?
someone help .. thanks!
https://www.sau.com.au/forums/topic/63569-hicas~help/#findComment-1217213
It is possible that it has been but you could never be sure.
That is a TOMEI hicas locking kit. It locks the Hicas in place. Usually good for better drifting, I wouldn't disconnect the Hicas for circuit though.
Sounds like it's had quite a bit of work done.
https://www.sau.com.au/forums/topic/63569-hicas~help/#findComment-1217512
it's probably got a hicas lock kit, however the tomei plug-in thing should stop the warning light from coming on.
Alot of people also get the warning light come on when they have an aftermarket steering wheel.
leave it as-is, most people prefer hicas turned off coz it makes the car's handling a lot more predictable (but also less idiot proof)
https://www.sau.com.au/forums/topic/63569-hicas~help/#findComment-1218012
yeh it does say TOMEI hicas locking unit.
so i shouldnt have a problem driving around sharp turns an shiet ..?
no wonder the car handles really good ... specially at take off ..the back doesnt even sag down when on full boost then change to 2nd all u hear is a small squek and continues..
thanks guys ..
https://www.sau.com.au/forums/topic/63569-hicas~help/#findComment-1218380
    • I might have to shoot them an email. Pity the exchange rate is so bad at the moment. BTW, thanks for posting that table makes interesting reading.
    • Add these Sensors -Wideband, Oil Pressure, Fuel pressure, Intake air temp Good inspection of ignition system of coils, plugs and loom (12v feed and good ground)- a r35 kit is best bang for buck upgrade. A decent tuner should be able to see any issues with the trigger system- a link has good filtering but a good simple upgrade is the nz wiring bolt in kit. Check and replace all the fuel filters- you would be surprised at intank filter after a few years. Also good to check for any leaks on vac hoses and pipe work as has been said. No need to go overboard and spend big $$$ to enjoy the car. A quality tuner is getting harder to find as anyone with a laptop thinks they are a tuner. A link has great features to check sensor voltages and frequency inputs and easy to see live by pressing f12. The link can do a TPS & RPM fuel/ignition mapping on ITB cars then add a 4D table with MAP and ability to add a 5D to it (can help with economy at cruise with wheel speed vs TPS) Where are you located as that will help narrow down a good tuner ?
    • Reviving an old thread, I reckon my stagea is starting to slip. Car usually gets parked on a hill, narrow driveway so cant go up the driveway smoothly, anyhows, lately first gear feels "sluggish"? Not responsive. Feels like I gotta run the engine more than usual to get off the line...  Any recommendations for transmission servicing in Sydney? Or possibly just an excuse to go manual ?
    • Well, moulded carpets should fit well if the buck they use is the right shape. The finish is then just a case of stiching the trim around the edges. Shuoldn't be too hard to get it right. Back in the day, replacement carpets were all "fitted", in that they were stitched together, with cuts and slices taken out to make them form the shapes. Many more opportunities to get it wrong, hence all the concern over good vendors and bad vendors.
    • A timely blog via AASA (keeping in mind they sell brake fluid of course...) https://www.msbgarage.com/blog/news-and-blogs/brake-fluid-what-should-i-use/
