Hey guys, i copped a canary for a few things
Wanted to find out if its bullshit or not
No.1 back spoiler brake light inoperative
No.2 back licence plate light - only one works
No.3 - i have silver plates on the pedals and not enough rubber so
if its wet i could slip
No.4 - i have an air pod filter & front mount intercooler
Copper says u can either have one or the other
Is that true why?? and if so how do i get away with having both??
Appreciate the replies and if u have been pulled up by cops
Also the BOV - they said on the canary " not to vent externally "
Something about u have to have it plumb back or something.
Thanx :rofl:
https://www.sau.com.au/forums/topic/63573-canary/
yes, all are defectable: Breakdown.
1) all cars complied must have a highmount stoplight whether its on the spoiler or in the back window. Canary!
2)The lights are there for a reason, ADR states both must work otherwise it wouldn't have two lights to begin with. Canary!
3)what they said is true in the eyes of the law.
4)You need permits for the air filter and intercooler. Get em at the pits or regency of whatever you call it.
BOVs are illegal cause they are too noisy (some) and most are externally vented where the air comes out instead of being recirculated ala the factory valve. This confuses the computer, it over fuels and emissions are raised. So get a plumback like factory or replace the stockerm for the pit inspection.
cheers!
https://www.sau.com.au/forums/topic/63573-canary/#findComment-1195288
you basically need permits for anything you don't wanna get picked on for. they're required when changing from the factory specs. Its just beauracratic shit.
Your licensing centres or pits should be able to issue you a Dept of planning and infrastructure mod permit for most things. A BOV is not one of em due to the emissions stuff I said before. just take it off, get your canary off then put it back on.....
https://www.sau.com.au/forums/topic/63573-canary/#findComment-1195461
yea so now thats how u get a POD setup aswell as a FMIC... thought it was just one or the other... i seriously dont see as to why if u have both, its illegal, when u can have one or the other...
btw if u have a partition and POD inside... and a FMIC, is that legal?
or a partition for the air intake at all is it legal?
where can i get all this ADR shit so i know i just came down from queensland and we get away with blue murder...
if until u do something stupid and they see u do it... which 99% of the gold coast area are dumb enuff to do, and still think their king shit for doing it... *thumbs up to them the tossers* *sarcasm*
and ps... not all of em are bad... i know quite a few that enjoy their privilages having a license, me included....
https://www.sau.com.au/forums/topic/63573-canary/#findComment-1195511
In Vic the rule is one intake mod only....POD or FMIC, but not both UNLESS the car came stock with an FMIC (eg GTR) in which case you can have a pod as well, but the FMIC must be stock standard.
Enclosing the pod doesn't matter, the above still applies.
Also there's no permit you can get that will change this. It seems that you can get a permit in other states.
https://www.sau.com.au/forums/topic/63573-canary/#findComment-1195535
in vic, it's basically an aftermarket cooler/pod (so a sidemount cooler that is larger than standard is also illegal if used with a pod)
As already said, u can't get a permit in Vic, just use the stock airbox and put a good filter element in it.
for more info, check out these letters http://members.austarmetro.com.au/~toan/EPAData/
all of those things are legit defects, probably a little harsh, as they are fairly minor items, but nonetheless still defectable. And if the cop wanted to be a prick, he would have made u tow the car home. Look on the bright side, they are all easy to fix. Welcome to Victoria - the police state!
https://www.sau.com.au/forums/topic/63573-canary/#findComment-1196140
Can't say I've heard of the one intake mod thing. Sounds like a lot of bureaucratic BS too me. Can't you guys get a car engineered in VIC?? My understanding is that:
1) Pods need to be engineered due to increased induction noise. A simple drive by sound test by an engineer is all that is needed to clear this.
2) FMICs need to be engineered, mainly because it is a "modification", hence a certificate is required for it, but also because it also supposedly raises emissions from a vehicle :bs!: While an engineer can give you a certificate for this modification, I've been told that for it to be air tight (i.e you can't be defected), it must also be accompanied by an emissions test on your car.
In NSW (I don't know whether this is different in other states), both a pod and a front mount intercooler, or for that fact any modification, can be done to your car as long as it is engineered etc etc.
The easy way out, of course, would be to return to stock. :)
:D
https://www.sau.com.au/forums/topic/63573-canary/#findComment-1196301
you probaly haven't heard of it, because you don't live in victoria :-p
If you install any FMIC(or technically any mod), it has to be ADR approved, and to prove that is meets ADR's you will need an engineering certificate.
This is a separate issue, the EPA has it's own regs. it gets a little confusing because there are several parties involved. Your best bet is to contact the EPA and find out what you need to get done. What they will most likely tell you, is that you can't have an aftermarket pod and cooler, regardless of whether or not both those items have engineers certs
https://www.sau.com.au/forums/topic/63573-canary/#findComment-1196332
This is all very well and true but the fact is i bought the car a month ago with the road worthy
So assuming that the car with the current mods is actually road worthy
Im thinking maybe it was a dodgy rwc that came with the car i bought
Another thing is i dont have a stock air filter and 2 i need to get a plumb back bov
Anywhere i can get the normal stock bov for the r33 gtst?
https://www.sau.com.au/forums/topic/63573-canary/#findComment-1196471
I dont think gtst's have stock BOV's. If your after a plumb back BOV you should be able to find a cheap Turbosmart one at your nearest autobarn. Does anyone know what a PBBOV sounds like? Someone once said it goes SSHHHFFFWUMP!
https://www.sau.com.au/forums/topic/63573-canary/#findComment-1196480
Pods are not a roadworthy issue, so the RW guy wouldn't give them a second look. I spoke with a Vicroads engineer (NOT a desk drone) about pods and he said Vicroads arn't interested in them because "....they are not an engineering isue". However he went on to say that the EPA would definately be interested and to check with them.
I have a stock BOV somewhere if you want to borrow it. If your piping is non-standard tho you might have trouble fitting it (it's a plumb-back type).
https://www.sau.com.au/forums/topic/63573-canary/#findComment-1196640
you could just block off where the bov goes. this is what i did, i just got a square piece of metal, drilled holes in it in the right spots, and then bolted it on. Block off the vacuum line and you'll be sweet.
It won't do any damage running no bov, just drive it easy. Some people say you can do damage to the turbo without a bov, but that's yet to be proven, and S13's for example don't have a stock bov.
alot of roadworthy places may be unaware that those things constitute a defect, as alot of mechanics wont be too familiar with imports, and can be some confusion over what is stock or not.
My mechanic didn't pick up on a few things on my car - pedals, steering wheel (not padded & smaller than legal), air filter (oiled pod), drift handbrake button, gear shift didn't have shift pattern printed on it(yes, this is defectable), height adjustable suspension (can't have suspension that can lower car to illegal height, also suspension travel wasnt within 1/3), braided brake lines, rear tyre had a chip out of side wall
most of those things are fairly minor items, but just goes to show that they do miss things, it's only human!
cars early 1989 (i think march or april) and before didn't need a high mount brake light, and besides, the light could have been good when u bought it, and the globe blew later.
if you suspect you received a dodgy roadworthy, have the car checked out by your mechanic. Alot of the suspension & steering components such as rubber boots & bushes are not repaired if the roadworthy is dodgy, those are long-term wear items that should have been picked up if there is anything wrong.
If you call up Vicroads they can give you advise on how to handle the matter. The tester can loose his license for doing a dodgy RWC, and usually what happens is they will have to fix all the problems free of charge. Otherwise, it gets taken further and they risk loosing their license.
https://www.sau.com.au/forums/topic/63573-canary/#findComment-1196713
Hey, Yeah well my dad manages a repco store and will be calling the guys up who did the rwc for when i bought the car so ill wait until what they say
If this is true then yes they will get into alot of trouble and obviously rw my car free of charge
But the strange thing i dont have a water bottle for my wind screen wipers which u must have which the cops didnt pick up when pulling me over
It was remove i assume as when they put the fmi there wasnt enough room as the pipe that runs into the fmi has no room for the bottle to sit.
But in regards to the bov, ive been told to take it off, put a bracket of some sort to cut it off until i get a plumb back.
Currently i have a blitz bov so im not sure if i have standard piping or not as these mods already came with the car when i bought it.
Cheers.
https://www.sau.com.au/forums/topic/63573-canary/#findComment-1196733
I've been in the situation when a car i bought had a dodgy rwc. You're better off getting a roadworthy report done by your mechanic, before jumping to conclusions.
Better to be armed with that before you accuse the mechanic who did the original roadworthy, and you might miss things, and he wont fix everything.
https://www.sau.com.au/forums/topic/63573-canary/#findComment-1197744
......... you can't have an aftermarket pod and cooler, regardless of whether or not both those items have engineers certs
Wouldn't the engineer need to take into consideration the EPA?? It seems silly to me that a car can meet the ADRs and still be a worry for getting defected by the EPA. Surely if you prove to the EPA that a pod and an intercooler do not increase emissions (and that they are roadworthy) that they would have no reason to take any action.
https://www.sau.com.au/forums/topic/63573-canary/#findComment-1198868
    • Should add all mods on the car are done in my ownership. The car was a 1 owner in Japan and I'm first owner in Aus.
    • Thanks GTSBoy. Did BC's so not Japanese coilovers. I've already done all the other points you mentioned besides the seat, I like the factory seats and want to keep original look. Done all the fluids and comp tests etc and all consistent and clean. Well and truly used to the power and car as I've been driving it for a few years as it is now. Contemplating next steps mainly. Preference to remain twins too. @Murray_Calavera Paying for labour.
    • Hmm. I don't think it is possible. As soon as you start, you will be on the hook for all the money. $5-10k is enough to make it fragile. Here's the list of things you need to do to make it nice, and driveable. If Japanese coilovers, get them measured and tested, then decide if you're keeping them or replacing them. If low rate springs, then consider big ARBs. If high rate springs, then probably leave stock ARBs. Either way, ad decent end links. Replace and/or upgrade all suspension bushes. That's LCAs front and rear, UCAs & traction arms at rear, caster rods at front. I highly recommend GKTech FUCAs, although the step to spherical joints is a step too far for some people. Rebuild brakes front and rear. This means making sure the calipers are healthy, discs are up to thickness, hoses are replaced with braided. Add good pads and fluid. Investigate wheel bearings all the way around, tie rod ends all the way around, upright bearings at the front, balljoints everywhere. Any of these that are still original are likely to be a bit wibbly nowadays. Bride or Recaro driver's seat, with fairly deep sides. Nice tyres. Street performance wheel alignment. Or track focused, if you're not going to use it on the road. Fluids everywhere if not known to be fresh. Now, learn to drive the car as hard as it will go, before trying to add any power. Save up big $$. $5k is the minimum cost for putting a decent ECU into it. A big single, with manifold, new exhaust, injectors, fuel system upgrade, ignition upgrade, triggering upgrade, etc, is >>$10k. None of that (except the ECU) is a good idea on an old RB. You really should put head studs in it, investigate engine health (compression and leak down, real oil pressure at revs, coolant condition, etc) before even considering adding power. There's nothing sadder than the "I added boost then it shat the bed" thread.
    • Are you doing the work yourself or are you paying for labour?
