Seeing as it was such a lovely night last night (cold) i thought i would go and practice some drifting around the factory areas at 3am when there isnt anyone else around.
It lasted one corner :P
Did ok coming into the corner.... coming out of it was a little different.
Was holding it sideways quite well going down the rd after the corner but let off the accelerator (i think this is why it happend) too much and the tyres gripped and threw me the other way more than i was meant to and was about to go head on into the meadian strip so i punched the accelerator all the way to the floor to get the wheels spinning and try and pull out of it and managed to flick it the other way and slow myself down a little more before hitting the concrete/grass sideon with the back wheel.
All i got out of it was a flat tyre (rear tyre sperated a little from the rim) which cost $20 to fix! :D
Think i will just wait until the good doctor shows me properly :)
https://www.sau.com.au/forums/topic/6358-ooops/
Originally posted by Silver-Arrowz
Lifting off throttle suddenly when oversteering causes it to snap the other way. Lift off easy.
hehe yeah i found out the hard way :P
ex - it would have been soooooooooooo embarasing if ppl were around lol
luckily the exhaust didnt get damaged either.
https://www.sau.com.au/forums/topic/6358-ooops/#findComment-95340
Originally posted by akeenan
was this in the moorabbin area? near cochranes road?
nope... thats another good place to do it tho at around 3am as its empty
was around the dingley/springvale area
https://www.sau.com.au/forums/topic/6358-ooops/#findComment-96314
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
