hey, i just put on a gfb boost controler (best $70 that i have ever spent as it holds the boost alot better than my previous turbosmart bleed and doesnt spike as much)
Im 97% sure its set up correctly, but im getting like what would happen if you hit the rev limiter? - thats the best discription i could give...
is this a fuel cut or will i need better spark plugs as the boost is blowing the sparks out?
any one else had this problem? or kno what wrong?
thanks guys.
https://www.sau.com.au/forums/topic/63620-fuel-cut-11-pounds-need-help/
i raced a s2 r33 lastnight and was dead even, and i had that possible fuel cut. if i fixed this problem id chop him. in my lil s1 33.
Their is no difference, it all comes down to mods and the driver.
Dont race... and if you do.... dont post it.....
As previously stated many times before....
Question "Why are you running a $70 part in a $15,000+ car"????
Do it properlly, buy an elecronic boost controller and fuel cut defender.....
Also i hope you have an exhaust and front mount... 11psi is the absolute max you should run on a stock setup...
Ppl's,
I had a problem this morning with my R33 96 S2, i have had it for a couple of days. It has a FMIC, exhuast, BOV, POD & running at 11psi (so they say).
I have given it a bit through 2nd & 3rd gear, but this morning i was in 4th@60-70kph & when i accelerated and it hit boost, it cut out, is this the boost cut.
Just dont see why i did not get this problem in 2nd or 3rd gear.
Any idea's.
PS, i dont know how they are making it do 11psi, no EBC or adjustable T piece in the engine bay, but i was told it hit 12-13 psi when it was dynoed.
PROBLEM SLOVED!!!!!!! :headspin:
i did my homework on this problem and found that it was misfire... ( The extra boost blows out the spark before combustion ) As the stock sparkies are only set up for stock boost. When looking through my lil bros hot4's mags i found a 3page article on sparkplugs. Regapping your plugs from 1.1 (stock) to 0.8 should fix this problem. AND DID MINE :headspin:
There is a cheep way to fix this if your on a budget and a expencive way. i chose the expencive way...
CHEEP WAY.
Go to your local hardware store and get a spark plug gapping tool. Not sure what they are called but they tell you what size your gap is.
Pull your plugs out and tap the tip on a hard surface, then with your new gapping tool ajust it to 0.8, put your sparkies back in, up tha boost n take it 4 a spin.
You can get aftermarket 0.8 pre gapped plugs from autobahn for under $5ea.
EXPENCIVE WAY.
I got the NGK Iridium ix plugs. I payd $20 each and that was with a discount. but if you have future plans of upping the boost above 13psi these pluge are recomended.
as the 6 type stay colder... ive heard ov ppl uping there boost that hard that there sparkies golw red and ignite the fule with out a spark.. trust me you dont want this to happen. you can even go 7 but thats only recomended for over 2bar.
Iridium plugs stay cleaner then your average plugs and are anit-oxidation and anti-corrosion, they apparently last forever too. :headspin:
these plugs are gapped to 0.8 already so you dont have to fcuk around trying to get the correct gap size.
Mad free advertising for NGK...
I :ghost: If you have ever changed your plugs (skyline owners) youl know that its a mission :ghost: took me and a mate well over an hour :ghost:
Do your homework before you go out and spend hundreds of $$ on plugs, but in my oppinion its better than a dead rb25. and well worth it.
Thanks Gamatron ;)
I will check out the gaps on my skyline, i had a R33 S1, that was boosted too 10psi running the stock plugs & it was fine but i did end up changing them too NGK Iridiums.
  • 3 months later...
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
