Is this the older model with the monochrome display and 2 dials?
I don't have an installation manual but have done it recently as it's fairly easy to install.
Basically:
On the solenoid there are 2 nipples, one marked "in" goes to the boost signal from the compressor housing or where ever it comes from. One marked "out" goes to the actuator.
AS for wiring the head unit: Red is a switched ignition source, black is earth. blue (i think) and white go to the solenoid and should match colour for colour if you have a genuine solenoid.
good luck
Dave
Looks like a newer version of the one i have. If there are only the 4 wires in the main plug then the wiring is the same. The second small plug is to plug into other blitz stuff.
Forgot to mention you need a boost signal to the back of the head unit, pick it up at the same point as your boost guage or tee into the boost guages line for it.
