I'm in the market for some new rears *heaven knows why?*
Just like some feedback on what tyres you all have on and are you happy with their grippiness (if there is such a word)?
Been quoted ~$420ea for Dunlop Direzza's DZ101's which i'm told is the "best money can buy" and ~$340ea for Toyo TPG Trampio's in 255/40/17 size. Obviously a bit of range there so want to see what every one else is using.
Cheers!
Dave
https://www.sau.com.au/forums/topic/63650-what-tyres-are-you-running/
  • Replies 56
potenza DAGG.... Yummmmmmm 255/40/17
have no idea how much they would cost plus they came from Japan, no Oz companies made by the looks of things..... but yeah a lot happy than my g-grid i used to have plus the old potenzas....
if ya see any floating around try and grab em.... well i like em anyway:-)
I got a set of Toyo Trampios for $1100 from tyrepower in port kennedy
2x 245x40x18
2x 265x35x18
Tyres are pretty good and service there from the boys are great. Im guessing something in 17inch would be a bit cheaper than that. My personal experience is that tyre places rip people off whereever they can. You get a quote for the exact same tyre down the road for $80 more.
Kuhmo Ecsta Supra 235/45R17's on the front
Kuhmo Ecsta 711 255/40R17's on the rear...
the Supra's are nice, lasted a fair while and grip nicely...
the 711's.... well.. they suck.
i washed my rims perfectly spotless last night, drove around a little bit last night (absolutely no wheel spin or anything) and you can see powdered rubber sitting in the spokes of my rim(rear rims only), they wear that quick its not funny...
going to try Nankang NS2's next i think, mate has them on his wrx and they handle nice
I used to run Maxis 265/35R18's on the rear
and Maxis 235/40R18's on the front. For a pretty unknown(?) and cheapish tyre they had wicked grip on both wet and dry road. Cost about $430ish for the 265's not sure on the 235's maybe $380ish. But with me only running about 250rwhp and you running what now 350rwhp might make a difference.
Z rated means they are high speed rated, over 160km/h so thats what you need on a tyre.
don't get GT Radial Champiro's hard as rocks and shit in th wet, but hey if you want burnout material they will go on for a while but i wish i never got them.
Falkens are always mentioned as a great all round tyre.
Sherriff,
I just put a pair of the Ventus 104's on the 32 a month ago.. pretty DAMN GOOD tyre for the price.
They are up there with S03's in the dry and are about 150$ cheaper per tyre so you can't go wrong.
I havent tried the 104's in the wet yet. S03's have been the best tyre ive used in both the wet and dry.
Shaun
    • Unfortunately haven’t taken pics yet after it was finished. All the edges are hemmed nicely, just had to cut holes for the gear shifter and seat bolts and seat belt bolts in the rear. The molds seem like they’re done with steam and a layer of glue on the underside to hold a bit of shape but still soft enough that it’s a good fit when it’s all pressed down.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
