I'm in the market for some new rears *heaven knows why?*
Just like some feedback on what tyres you all have on and are you happy with their grippiness (if there is such a word)?
Been quoted ~$420ea for Dunlop Direzza's DZ101's which i'm told is the "best money can buy" and ~$340ea for Toyo TPG Trampio's in 255/40/17 size. Obviously a bit of range there so want to see what every one else is using.
Cheers!
Dave
https://www.sau.com.au/forums/topic/63650-what-tyres-are-you-running/
  • Replies 56
potenza DAGG.... Yummmmmmm 255/40/17
have no idea how much they would cost plus they came from Japan, no Oz companies made by the looks of things..... but yeah a lot happy than my g-grid i used to have plus the old potenzas....
if ya see any floating around try and grab em.... well i like em anyway:-)
I got a set of Toyo Trampios for $1100 from tyrepower in port kennedy
2x 245x40x18
2x 265x35x18
Tyres are pretty good and service there from the boys are great. Im guessing something in 17inch would be a bit cheaper than that. My personal experience is that tyre places rip people off whereever they can. You get a quote for the exact same tyre down the road for $80 more.
Kuhmo Ecsta Supra 235/45R17's on the front
Kuhmo Ecsta 711 255/40R17's on the rear...
the Supra's are nice, lasted a fair while and grip nicely...
the 711's.... well.. they suck.
i washed my rims perfectly spotless last night, drove around a little bit last night (absolutely no wheel spin or anything) and you can see powdered rubber sitting in the spokes of my rim(rear rims only), they wear that quick its not funny...
going to try Nankang NS2's next i think, mate has them on his wrx and they handle nice
I used to run Maxis 265/35R18's on the rear
and Maxis 235/40R18's on the front. For a pretty unknown(?) and cheapish tyre they had wicked grip on both wet and dry road. Cost about $430ish for the 265's not sure on the 235's maybe $380ish. But with me only running about 250rwhp and you running what now 350rwhp might make a difference.
Z rated means they are high speed rated, over 160km/h so thats what you need on a tyre.
don't get GT Radial Champiro's hard as rocks and shit in th wet, but hey if you want burnout material they will go on for a while but i wish i never got them.
Falkens are always mentioned as a great all round tyre.
Sherriff,
I just put a pair of the Ventus 104's on the 32 a month ago.. pretty DAMN GOOD tyre for the price.
They are up there with S03's in the dry and are about 150$ cheaper per tyre so you can't go wrong.
I havent tried the 104's in the wet yet. S03's have been the best tyre ive used in both the wet and dry.
Shaun
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
