  • Replies 56
Dry is best obviously. But in the wet they're not the worst tyres, the cheaper falken ZE326 is by far the worst in the wet.
Launch is pretty good..... drift is for fags, so I wouldn't know :D
Oh, and I get them from a RICE Supporting tyre shop in mandurah so those prices might slightly lower than normal prices. Either way, good value for money :)
I got sumitomo HTRZ on the back of mine and have found them to be great
I paid 250buck each for 255/40/17
even when they do let go, they still keep bitting for traction
Or Toyo Proxy are apparently quiet sticky, but the softer they are they quicker they wear down, and at $470 each go, I'll stick with the sumitomo's
i chew thru any tyres i have :)
On my zed i had the potenzas .... nice tyres .... but due to unfortunate circumstances .... such as swerving to miss dogs ..... nails and other gizmos getting stuck in them ..... i went thru them pretty quickly.
On my skyline i have Kumho Supras .... which were nice while they lasted ..... 8 months on and i chewed thru the rubber, the canvas, the belts and another set of canvas ..... yup definately got my wear outta those.
Now i have paulies tyres :D tyres are like kids ..... so much nicer when they are someone elses :)
can get them from tempetyres over east.. dunno what they charge for the rears, but i know the fronts you get for $140, you can get for $125 + $10 postage per tyre from over there.. so id say ~$200 for the rears too
Nizmo - yeah the kuhmo supra's are nice.. but the 711's are shite.. pity ive got supra's on the front and 711's on the rear :)
On your stocker rims ? Your a dickhead.
I pay $200 for 255/40/17, and $140 for 235/45/17. Cheap Nankang NS-II's that grip like all hell :D Im happy with them :)
today i am picking up my 265/35/18 Hankook ventus (rear) and 235/40/18 front (forget what they are) ill tell ya how the hankook's go sherriff Wan when i get em on
read the whole thread next time b4 calling me a dickhead - Paul (@dad's)
Cool guys thanks.
I was gonna go for the TOYO's as i got an awesome price $800 for all 4 235/45/R17
Anyonw in mel let me know if you need a set. And before you ask NO they haven't fallen off a truck :rofl:
I paid $700 for Firestone Firehawks that size they have been pretty good so far had them on for about 7k kilometers better than the Kuhmos i had on b4
Cheers for all you replies! Keep them coming. I can't believe some of you like the Kuhmo Ecsta Supra's. I have them on now and I hate them! Each to their own.
same, they have probably been the crappest tyres I have had on the 32.
Shaun
i got a new pair of khumo's on the back... cheapies.... 145 apeice, used to have nankangs, but the just meltd in 15000kms, though that was the rears the fronts are stll goin hard....
speak to paul at tyrepower canningvale... a really good bloke who gives great prices....
ps. i think we may be needing a tyre company as a sponser.....
  • 1 month later...
Digging up a bit of an old thread but i've decided on going with the Toyo's. Seem to be the best mix of good reputation from other users and price. The price difference between TPG's and the new T1-R's was negligible so i'm going for the T1-Rs in 255/40/17's for $340 each from Booragoon Tyre Service in Myaree. When I go down there to get them fitted, i'll try and sound him out if he's interested at all in becoming a club sponsor for all the SAUWA members. He's only a small outfit but it would benefit him no end, particularly given the number of you out there using Toyo's.
Await a full review of the tyres once fitted :cheers:
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
