i'm from horsham, vic (3 hours from melbourne), where is mitcham in regards to the city of melbourne??, i'd be definetly down for the tinting on my cefiro, would this be $145???  Can it be done on a weekend and when is this going ahead???  PM me if you want
David Argent 0412 458 460
on a previous post:
they are Premier tint 447-449 Whitehorse Rd Mitcham - Melways 48 H9
Owner: John Piper 9873 4777
You can call me for more details 0401 598 511
I'm 95% sure sedans are the same price as a coupe. will double check tmoz
  • Replies 134
Here is a current confirmed list. Keep it up guys!
1 me
2 saff_cossie
3 silva33
4 negitive
5 x2
6 QWAK
7 Interloper
8 Jetdat
9 x2
10 skylinegeoff
11 x2
12 sarumatix
13 babia
14 oz_cefiro
15 West
16 Zombie
17 rrrage
18 RTFGTR
All those on the list thanks for all your details. I will compile them together
shortly and get the list off to John. Maybe we should get 20 first??
It will be each persons responsibility to book in their car at whatever time they want.
I will let you all know when John has the list. It won't be for a a few days yet. We'll see if there is any more interest first.
1 me
2 saff_cossie
3 silva33
4 negitive
5 x2
6 QWAK
7 Interloper
8 Jetdat
9 x2
10 skylinegeoff
11 x2
12 sarumatix
13 babia
14 oz_cefiro
I'm in :headspin: , West (0433234241) that makes the list up to 15 now isn't it? Let's kick off.
Please find out if he will do 20% on driver/pass windows.
im pulling out if he doesnt.
Also note, for rear windscreens you guys are gonna have to take out yor rear speakers, and probably seats to make life easy
There's his number, it's his business. I'm just organising for the masses :P
And you will note you are actually not on the list as you haven't confirmed yet.
1 me
2 saff_cossie
3 silva33
4 negitive
5 x2
6 QWAK
7 Interloper
8 Jetdat
9 x2
10 skylinegeoff
11 x2
12 sarumatix
13 babia
14 oz_cefiro
15 West
Put me on the list... I have no tint at the moment... nothing at all:(
0425739358
PM Sent.
JetGTS: can you confirm with John if he wants us to pull the seats and speakers out like R31Nismoid said?
Thanks
Adam
Yep sure I will get some answers for everyone's questions. I'm going in on Monday with the list so let me know if there is anyone else tonight or by tomorrow morning.
OK everything is now confirmed. You are all welcome to book your cars in as of Tomorrow morning (Tuesday) Please ask to speak to John Piper as he is the only one that knows what is going on. 9873 4777
Give him your name and number and he will mark you off the list.
In answer to peoples questions,
- They have all types of quality film to use for those that want extra dark. i.e. 5% 20% 35% etc. and also reflective, black and so on. No problems there...
- And also for those that enquired about removal of rear seats and speakers for a coupe:
If your speakers are extra close to the window or anything is pressing up against it (different parcel shelf or something) then it willl be in your interest to remove them, as they will do it any way if need be. You can also make it a little bit easier and take the top of the back seat out, but in most cases this isn't necessary.
Those that haven't put their name down still can, just PM me your details..
Start booking! :jump:
cheers guys, Ben
    • Bit of an update to this one. Having some issues on the dyno that held us back (boost spiking) and I want to pass some info over you guys and see what you think is wrong with my setup. The current readout on this dyno is 462rwkw on a low reading dyno so keep in mind it is a real world 500rwkw setup on a hub dyno. Don't read into the power figure too much as a sign of the issue. The short and curly of it is: 2.8 Litre Racepace build RB25 NEO N/A Head with VCT (internally standard however ) Borgwarner EFR 8474  Turbosmart 50mm Straight Gate + Mac valve 6Boost Manifold 4" dump to full 4" exhaust (nil restrictions) Wastegate plumbed back in and all angles in the exhaust system are acceptable and not too sharp. GFB SV52 BOV in cooler piping  Turbosmart BOV in EFR Housing   The issue we are having is it comes onto full boost for example at 4000rpm and spikes to 24/25psi, before dropping down to 17psi before slowly rising back up to the target boost of 23psi. It was extremely uncontrollable and the tuner actually had to ramp in boost progrssively with each 1000rpm on each boost setting we selected to try and reduce the amount of spiking. Sometimes we would see a drop of 10psi from the peak at the beginning of the run, to the low, until it took the next 500-1000rpm to stabilise back up to the target boost. The tuner is pretty confident that the straight gate is just a poorly designed product and leaks too much boost upon cracking the gate open and theres no way to fix it other than going to a poppet valve. He's also confient theres no ignition breakdown or floating valves. The fueling is extremely stable as well. Turbo speed is somewhere around the 109,000rpm area. The spanner in the works for me is that prior to this Borgwarner and StraightGate, the car was tuned on -5 twins at a diferent tuner, and he also had issues controlling the boost with it spiking around the same rpm range, so to me this sounds like the same issue and it can't be anything on the turbo side as this was all changed and I think the behaviour is extremely similar, if not the same. We also removed the mac valve and did a run on wastegate pressure and it still spiked and had the same behaviour. My thoughts on possibilities are: Boost Leak VCT Cam Gear isn't reliably activating consistently - (On this however, we did a run with the VCT disabled and the boost still spiked) Turbosmart BOV is not handling the boost? However this seems unlikely to not be able to handle 20psi. I have a couple of logs that I can't make sense of if anybody knows how to read them and can obtain further logs of other parameters if they are not enough, happy to pay for anyones time. The dyno readout with the power figure is the most recent last week. The other picture is from two weeks prior to that where we couldn't break 400kw (we removed the cat), however the issue of the boost control persisted. @Lithium @Piggaz @burn4005 @GTSBoy @discopotato03 I've tagged those that were quite active in recent pages here, no disrespect to those that know turbos well but I missed tagging. Cheers
    • I recently purchased a 2018 Infiniti Q60, which has an SD card navigation map. I can see my system has options for real time traffic updates etc, and am wondering if there is something I can purchase to get this working? I can see there are at least updated maps for USA and Canada, but nothing for Australia. Surely Infiniti took changing road systems and city expansions into account when they decided to use an inbuilt navigation over Android Auto/Apple Car Play, or are we doomed to drive on streets that don't exist in the navigation system if you drive to a new area?
    • Luckily I didn't put in etch primer as I just found out it's not compatible with my body filler lol. Also just need to sand the panel anywhere between 150-400 grit so I'm in the clear there. It does say to not apply to soft old paint, I assume that means paint that is flaking, peeling,etc
    • @dbm7 and @GTSBoy thank you both very much! will give that a shot!
