  • Replies 67
OK found my invoice....it was $368.35 in parts and $893.75 for labour.
You'd save a bit on parts as they needed silicone hoses and a couple of bits with my set-up as it was a butchered R33 manifold...whereas an R33 intake manifold will bolt straight up to yours. Also the dump-pipe gasket and manifold gasket + welding the exhaust was over $100....the stock R33 dump will bolt in place for you...the R34 has a longer front section so I had to pay for extra fitting.
Hope that helps!
It was 16 hours of labour...but spread over 4 days, they could have hit it in one go and done it in 2 days I suppose...I'd imagine bolting the bits on a 33 would be a hell of a lot quicker.
They didn't tune it, it was sent to APC to tune the e-manage, but the least said about that the better....depending on what you decide with the ECU will depend on what path you should take.
Aaron, I’d recommend getting hold of a GTSt ECU and plugging it into your car to see if you get any error codes…I’m 99% sure after looking at the wiring diagrams that the ECU won’t see ANY difference…unlike the R34 ECU *sigh*
Just get a loaner, it’ll only take a few minutes to swap over and see, ideally just swapping the ECU and dropping the base timing a few degrees may be all you need to do.
i am going to contact perFOURmance and see what they think - lost my license for 6 onths - seems like perfect time to do it...
i reckon once i start it back on the road in 1 month i hope - need to get bits then get someone to do it - need to get my hands on a ECU too - then get the timing advanced a little....so much to do so little money :rofl:
  • 1 month later...
got an idea about water/oil lines.....
rather than getting holes bored in my block/sump etc a guy was telling me he did a bit of a **** around job on a old ford ute - bodge job but what he did for oil/water lines he simply tapped from say oil pressure line and radiator hose (or similar).
I 2was wondering if this would work with the rb25DE - be a hell of allot easier and cheaper
Ive been looking to do run oil/water lines without having to drill into the engine too. I dont have a digital camera on me atm but there is this copper pipe that looks like an oil line to me :rofl: its located towards the left of the exhaust manifold (underneth the nissan lable printed on the head (looking at manifold which on my right). What do u reckon... is this an oil line?
  • 3 weeks later...
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
    • So my car is finally back from paint! This took an absolutely insane amount of work and should get it's own build thread - but I didn't build it. It was completed by Troy @ https://scalekustoms.com.au/ I originally bought the AOSHIMA URAS Type R kit while I was in Japan, it's supposed to look like this when assembled: Now, I thought that was cool enough until I opened the box with Dismay, as there's no way I could possibly have completed it. The thing is 1/24 and has details down to the steering wheel horn button, which is a 2mm diameter sticker. I originally wondered if someone could make it at all, as is - But then things got a little carried away. It's worth noting that the model does not have an openable bonne, let alone engine bay, OR an openable boot. - Troy has worked wonders with 3D printer and presumably better eyes than I will ever have. My photos suck, so I will post up some of his in-progress ones he sent to me during the way. Unsuprisingly, he is very detailed. A lot of these are out of order. But he: 1) Made a LS engine and an engine bay appear out of thin air 2) Made the bonnet removable 3) Printed the rims I will buy in the future (or any rim you want) 4) Printed and added the wing that is going on 5) Tinted my back windows as this is what my car has IRL (privacy glass) 6) Added a licence plate. 7) Somehow did the interior 8) 3D Printed my actual seats 9) Made the exhaust under the car connect even though this is likely invisible. 10) Created a boot with my fking battery box, power steering reservoir, subwoofer and toolboxes back there. To say it's insane is an understatement. And I f**ked it all up because when I was re-mounting the wing (it broke in transit) I spilled glue everywhere and ripped paint up and Gregged the rear half of the car. Which about makes sense. Also, this arrived on the same day. Quite the change from: I spent 16 hours per day over the next 3 days pre-christmas putting the interior back together, mounting lip, fixing various bodykit problems with window mouldings, etc. and servicing, rebuilding my 370z brakes to go on the car 'soon', messing with heights to check clearances for new wheels, etc. I also had a foray into mounting wiper-mounted washer jets which was an absolute disaster. The bodyshop has welded (and painted) over the stock jet locations for reasons unknown to everybody (i.e they forgot) I also wanted to wire in the oil pressure sensor on Christmas Eve which was a BAD IDEA. You do not know terror like pulling your ECU apart, pinning in half-fitting pins that aren't the right ones, but trying anyway because it's Christmas eve, putting your ECU back together and having a no-start condition with a fuel pump not priming. Then you undo all your work and the fuel pump still doesn't prime. So after all that terror and horror and pain and tedious disassembly, the issue was the relay in the boot which seems to have died/stuck when I was turning the car off and on about 700 times testing shitty washer jets. I also re-wired the fuel pump power plug which fell apart in my hands. I am very happy I had 3 extra pre-made ones from a few posts/last Christmas's breakdown. https://bluewireautomotive.com/products/10-x-pcm-ecm-ecu-terminals I have put an order for these in, so I can actually add the pins to the ECU properly. The commodore ECU does not have the pins for Oil Pressure via ODB2. However the ECU can support it if you create the pins and wire them in. So for round two, and somehow attempting to route that into the engine bay through my impossible engine bay grommet is a fight for another day. It's 40C in Melbourne tomorrow, I am half tempted to drive the car with the aircon on to deliver presents to my partner's family and see if it helps with the overheating-on-40C-days-in-traffic-with-aircon-on-only issue that the vents were intended to solve. Do I feel lucky?
    • Yes, while being... strictly unnecessary. Tuning is a bit like quantum physics. You don't need to understand what Schroedinger's equation actually means. You just need to run the computation and accept the answers. With tuning, you just push page up/down until the exhaust tells you that you've got the fuel right. The VE can stay hidden behind the curtain like the Wizard of Oz and you'll never need to know what he looked like.
    • The second part yes, the first part about easy VE calculation is something I've seen a few people talk about online.
