  • Replies 67
OK found my invoice....it was $368.35 in parts and $893.75 for labour.
You'd save a bit on parts as they needed silicone hoses and a couple of bits with my set-up as it was a butchered R33 manifold...whereas an R33 intake manifold will bolt straight up to yours. Also the dump-pipe gasket and manifold gasket + welding the exhaust was over $100....the stock R33 dump will bolt in place for you...the R34 has a longer front section so I had to pay for extra fitting.
Hope that helps!
It was 16 hours of labour...but spread over 4 days, they could have hit it in one go and done it in 2 days I suppose...I'd imagine bolting the bits on a 33 would be a hell of a lot quicker.
They didn't tune it, it was sent to APC to tune the e-manage, but the least said about that the better....depending on what you decide with the ECU will depend on what path you should take.
Aaron, I’d recommend getting hold of a GTSt ECU and plugging it into your car to see if you get any error codes…I’m 99% sure after looking at the wiring diagrams that the ECU won’t see ANY difference…unlike the R34 ECU *sigh*
Just get a loaner, it’ll only take a few minutes to swap over and see, ideally just swapping the ECU and dropping the base timing a few degrees may be all you need to do.
i am going to contact perFOURmance and see what they think - lost my license for 6 onths - seems like perfect time to do it...
i reckon once i start it back on the road in 1 month i hope - need to get bits then get someone to do it - need to get my hands on a ECU too - then get the timing advanced a little....so much to do so little money :rofl:
  • 1 month later...
got an idea about water/oil lines.....
rather than getting holes bored in my block/sump etc a guy was telling me he did a bit of a **** around job on a old ford ute - bodge job but what he did for oil/water lines he simply tapped from say oil pressure line and radiator hose (or similar).
I 2was wondering if this would work with the rb25DE - be a hell of allot easier and cheaper
Ive been looking to do run oil/water lines without having to drill into the engine too. I dont have a digital camera on me atm but there is this copper pipe that looks like an oil line to me :rofl: its located towards the left of the exhaust manifold (underneth the nissan lable printed on the head (looking at manifold which on my right). What do u reckon... is this an oil line?
  • 3 weeks later...
    • Yes, while being... strictly unnecessary. Tuning is a bit like quantum physics. You don't need to understand what Schroedinger's equation actually means. You just need to run the computation and accept the answers. With tuning, you just push page up/down until the exhaust tells you that you've got the fuel right. The VE can stay hidden behind the curtain like the Wizard of Oz and you'll never need to know what he looked like.
    • The second part yes, the first part about easy VE calculation is something I've seen a few people talk about online.
    • You 100% could do that, would save money on a gym membership lol. But yeah, getting a cordless orbital sander will feel priceless coming from doing it manually.  Good luck with it mate
    • I initially was going to do the whole car with a block then realised, it would be a bigger monster of the job 😂 I guess that's all part of the learning process. I appreciate all that advice, I think I got a good idea on how to tackle this whole job.
    • I admire your efforts with the scuff pad.  As a mere mortal, I use this for the baulk of my sanding work- https://sydneytools.com.au/product/milwaukee-m18bos125-0-18v-li-ion-cordless-125mm-5-random-orbital-sander-skin-only Yes you can easily create a low spot while sanding. There are 2 types of filler, 1 part of 2 part. The 2 part filler will get used for large corrections and the 1 part filler will get used for pin holes and areas that only need slight filling.  Depending on how zealous you are with the sander (very easy to do with a power tool) or if you are chasing rust etc, yes those low spots will need to get filled or you will end up with a very obvious defects in the paint.  Using the guide coat and large sanding block, high and low areas will be revealed (watch youtube videos for a good visual on this). Its up to you if you think its worth the effort to make the car completely flat before you spray it (you make it flat by filling the low areas).  At the end of the day, it comes down to time. The end result comes from the level of prep put in to the car. If you want a perfect result, you have to put in the time during the prep stage or else it will be impossible to achieve a perfect result during the spraying process.
