  • Replies 67
Seek and ye shall find
http://www.greddy.com/dir_tech.htm
You may have noticed Gatty that my car got stolen the other day, it's been recovered but may be a write-off, hope you have better luck with your turbo conversion!
  • 5 months later...
Yeah, im interested to know as well - my brother just turbo'd his honda civic vti-r and it was a very fun/interesting to watch. I wouldnt mind turbo'ing my car, shit engine - could probably get away with it reasonably cheap.. then if it blows i'll just put a stock one back in place.
Dayne
  • 2 months later...
  • 1 year later...
just on the topic of Dan's conversion for a minute.. i have played with heaps of RB25's turbo & not and i have found that the plenumn and runners on the R34 neo rb25de to be quiet tiny and restrictive compared to the RB25det.. (Even R33 non turbo).... Anyone else have thoughts on this???
Edited by webber
    • Duh... to answer my own silly question, it's actually described in the FSM... ...400 pages away at the end of the manual, for RB25DE/DET signal descriptions, it cites the TPSwitch signal action, is dependent on the TPSensor value ~ this tends to infer the builtin POT voltage signal is the primary, and the switches are fallback/secondary should the POT fail/TPSensor signal lost (and switch alone with no TPSensor signal allows for base idle speed setting).... makes sense... they (TPS units) used to fail/wear the POT with time, they're not exactly built to last ~ having the switch as a redundancy gets around this...(or, it's less likely both signals would be lost as they're on different power rails)... and of course wrt RB26DETT, you have to electrically disconnect the IACV solenoid from the harness, to defeat idle air control...
    • Dose is unaware just how much fun 145-150kw would be in a 2.5L NC MX5. It would be one of the most fun things to drive to ever grace SAU.
    • Same thought crossed my mind ~ depends on how one connotes 'stalling'...ie; gets a rough/stumbling idle as it get warm until it stalls... or... idles ok and simply falls-over when it gets to temp... ...you can test the whole circuit with a couple of resistors ...unplug coolant temp sensor, bridge terminals with a 2K7 resistor (ECU will do cold start), or with engine warm bridge with a 330R resistor (ECU will consider engine to be at normal operating temp)...it's a quick way to check wiring integrity/ECU response when you don't have a multimeter handy ...
    • They also make them with the motor mounted on the side
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
