Well the start of figuring out why my car runs like shit begun last week, The turbo is on its way out - the impeller is loosened up and starting to rub on the houseing and its only a matter of time before it breaks and sends blades through my engine...
So a new computer and turbo is in order - I have done alot of reading about just getting the rb25 one hi flowed and rebuild but this seems to cost between $1500 and $2000, might as well just buy a brand new turbo.
Im not trying to get rediculous high end power I'd rather low end the car being a drift car. What can anyone recommend?
The GT2530 seems like a reasonable option good price and about the power output I want anyone put one on an Rb25?
I have been searchin the forums reading all sorts of mixed results, so any suggestions would be greatly appreciated.
Oh and great news about getting your car back Nic!
I thought non-bb turbo rebuilds were under $1k and 2530s were more than $2k ?
Sucks about the turbz :
Depends on how bad the turbo is to start with and what gets done to it. My mates CT26 cost like $2500 for highflow and rebuild, exxy experience, but worth it.
a 2nd hand HKS 2530 should cost you between 1400-1800. They will be good for about 230rwkw, but the response will be fantastic on the 25.
You will probably find it will come down to what you can actually find. Bolt-on upgrades for RB's don't come up for good prices that often, and are usually snapped up pretty quick
G'day mate
I recently saw on Nengun.com that they have a kit which includes the HKS GT RS turbo along with four injectors, power fc and controller and GT RS kit for the RB25DET brand new for about $4800 delivered. Quite a fair whack of cash but you are getting avery good package at a very competitive price, Im trying to put the cash together myself as we speak. :headspin:
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
