Well the start of figuring out why my car runs like shit begun last week, The turbo is on its way out - the impeller is loosened up and starting to rub on the houseing and its only a matter of time before it breaks and sends blades through my engine...
So a new computer and turbo is in order - I have done alot of reading about just getting the rb25 one hi flowed and rebuild but this seems to cost between $1500 and $2000, might as well just buy a brand new turbo.
Im not trying to get rediculous high end power I'd rather low end the car being a drift car. What can anyone recommend?
The GT2530 seems like a reasonable option good price and about the power output I want anyone put one on an Rb25?
I have been searchin the forums reading all sorts of mixed results, so any suggestions would be greatly appreciated.
Oh and great news about getting your car back Nic!
I thought non-bb turbo rebuilds were under $1k and 2530s were more than $2k ?
Sucks about the turbz :
Depends on how bad the turbo is to start with and what gets done to it. My mates CT26 cost like $2500 for highflow and rebuild, exxy experience, but worth it.
a 2nd hand HKS 2530 should cost you between 1400-1800. They will be good for about 230rwkw, but the response will be fantastic on the 25.
You will probably find it will come down to what you can actually find. Bolt-on upgrades for RB's don't come up for good prices that often, and are usually snapped up pretty quick
G'day mate
I recently saw on Nengun.com that they have a kit which includes the HKS GT RS turbo along with four injectors, power fc and controller and GT RS kit for the RB25DET brand new for about $4800 delivered. Quite a fair whack of cash but you are getting avery good package at a very competitive price, Im trying to put the cash together myself as we speak. :headspin:
    • It's actually really good advice. And I do try to do it. I actually have 2x 3KG dumbbells that sit right beside where I sit. And I look at them a lot. Use them a little. But I'm trying to do more with it. At the moment I'm going through a heap of weight loss too which will help. I cracked into the 85kg mark this week. My weight used to have me sit consistently between 93 to 95KG! That definitely doesn't help. I've also got POTS, which flared up after I got slapped with COVID a few weeks back, and POTS really smashes fatigue and stuff into you, and has a thing even called "excercise fatigue". Basically even the minorest "excercise" (walking from the garage to the house) causes fatigue! And one of the treatments (Other than a med I'm on) is also... Excercise... Ha ha ha So it's why I'm trying to play the game of "might as well" and trying to push through things. For ADHD specifically, the general recommendation is "excercise". When you dig deep into it though, while any excercise is good, the best type is "explosive" excercise. So training for a sport like squash, tennis, even soccer. Things where you need to get the whole body able to "explode" into a different direction change. They've found with explosive sports, (I can't think of the proper term they have for it) that it actually makes the brain grow and become bigger in specific areas. The areas where ADHD causes those parts of the brain to be smaller than normal! But definitely, trying to push myself, and break those bounds mate, and get healthier!
    • Be more active mate.. , not taking the piss ❤️, your long term health will love you for it I would think something like a kettle bell or 2 laying around in areas you go past during the day would be awesome for ADHD.... "Oh look, a kettlebell", and exercise helps your brain health as well My mates son was a bit of a problem child, diagnosed wirh ADHD, and some other things that had his brain occasionally doing loops, until we got him into a training program, the difference after he started training was amazing, he had more focus, and his fitness levels exploded, it is like he is a totally different kid to be around Brain chemistry something something Stay fit stay strong mate
    • I had never actually looked into it, but aren't onboard compressors a thing in trucks?
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
