neo32
I also have a R32 GTR - and I had a similar problem( I think)
Try a 4 way wheel alignment (I took mine to a WRX guy here in Brisbane) My rear passenger wheel was out by a MILE – even tho I supposedly had a 4 way alignment from one of the 'mainstream' guys only a few month b4 (no names)
Also - check that your HICAS is working - I've herd stories about guys pulling the bulb out of the dash so you don't see the warning light come on.
HtH
Rear wheel alignment - excessive toe will cause the symptoms your describe. Set it neutral.
If you still have hicas, which i will assume you do, you need to ensure the rack is centered before it is aligned. I don't have hicas anymore because its crap, but I was told some Pedders shops have the tools or whatever to center it.
What do you mean tools to centre it. Do you mean the ignition key?
Coz when you switch the car off it automatically centres. Wheel alignments are set normally after that. It's only active steer rear ends that need to be locked in place. ie. Hondas
    • Took it for a drive to do some logs, I’m pretty sure my voltage issues and electrical noise issues are gone, I’ve sent a log to Adam and am waiting to hear back with confirmation  att.K23U9eHyiEJxixH6y1__GQfuqK0EgIoDgQFTs9G8x_w.mp4   idle video from that day just because
    • Went looking at mine, reading off the tyre, presumably these are 1st week of 2003. Still hold air (I haven't had to pump them up in over 12 months!)     I couldn't quickly find the date on the front tyres, they were fitted around 2008 to the rims, so probably not quite as old, but they have a lot more dry rot cracks in them. Still hold air.
    • I am now intrigued to go check the dates on the tyres on my Skyline... We need a game of who has the oldest tyre still holding a car up, and successfully holding air (for longer than a 2 weeks I feel is successful air holding).   I feel your tyres may be beating mine
    • Ok, still waiting for a date to get the cams installed on the MX5, why so long, because MX5 Mania has received a few new sets of different cams with different specs for the MZR and are currently trialling them, and working out what is best for 2.5 "powers" with stock internals, in the end if I go bigger than the Kelford stage 1 cams I'll need to look at the valve springs  Hopefully I'll get the news on them next week As for the boot of the car getting fixed, I hopefully pick it up early next week, I was sweating on picking it up yesterday but, meh, it was not to be, so ne weekend cruising for me
    • Ok got some old tyres for you guys...my car has been sitting around un-driven for about 6 years now. I had it on the original rims with the shitty compliance tyres it got it with back in 2006, which were manufactured in 2004... Sidewalls eventually rotted and split open, obviously no air in them and the rims were holding the car up. Just swapped them with some 17" Work rims and tyres which are probably 10+ years old too but at least holding air
