WRX Club - Rnd 2 - Phillip Island - March 12
  • Replies 290
Err..
As per usual, from sounds of things, might be me and a friend coming down tonight. I was expecting a few others to come down and enjoy the long weekend.
Just worried my friend whose house we are ment to be staying with may decided to stay in town. He is already working til 8 tonight, and wanted to bump this.
So just wondering, now that the wrx crew have nabbed places, anyone got space left? else i may be looking at driving down early tomorrow morning.
also appreciate if the leasee's can pm a mobile, so can meet up away from track.
hb/
update: ugh. just noticed the accomodation thread. if someone wants to move this over for me. if not, might be cruising with the megamart boys.
Can someone post up either Troy, Snowy, Adz mobile numbers regarding PI tonight - or send me a PM - I will only be able to head out of town by 8.30pm if at all. May end up meeting @ 7am with JAG and Ferni???????????? Fark'en work!
Joels website is http://www.inetpics.com/inetpics/inetpicsh.../index?OpenPage
I assume thats where they are going - he said he would be at the meeting Tuesday night, so im sure he'll let us know then.
Hey all
Once i get round to editing them all the images will go up on my site
www.inetpics.com/joelstrick
But will hopefully be running a slide show tonight nite at the club meeting as well as the pics from the GOR cruise
Il post up a note once all the pics are on my site
Cheers
Joel
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
