WRX Club - Rnd 2 - Phillip Island - March 12
  • Replies 290
So far the offical list contains the following people:
Snowman
heartbrkr
Roy
Ant95
pontiff
Since the list was posted (Friday night) ferni and Scotsman have sent in forms (that I know of)
It needs new turbo gasket, new EBC and a re-tune. If i was having a good monring at work i would have bought some brakes which would not have been fitted in time...but work sux again right now and i want all the money i can get in the bank. The projects im on wont die:(
Provided Ben can tune my car late this week, early next week and he doesnt find any problems then i should be ok. I want the susp to be given the once over as well as there is a knockign noise int he front right that is a bit unsettling:(
Ok have started an accomadation thread since it looks like it may become a logistical nightmare if we leave it too late.
If your planning to stay on Phillip Island between 11th - 14th post your details here.
http://www.skylinesaustralia.com/forums/sh...802#post1230802
Geoff will be there denham (I presumre) and also Anthony (heartbrkr) has one too - although to be very different his is a stock Auto!
sweet, what power u running now andrew? Nige told me ages ago you were getting a GT30 a bit bigger than mine, but that was back when u busted ur tranny.
Yeah denham looks like the R33 gtsts are in short supply for PI....I believe (according to my understanding) you should be running in the modified class (aftermarket inj + turbo) and I'm running in the std class but if you are still running street tyres it might be a close on track battle :)
r u using cheater tyres?
Denham......nah mate still on the cr@p (and I MEAN cr@p!!) street tyres. Had a look at them after Calder and theres a lot of wear on the insides of the tyres.....means my SFA traction has gotten worse :)
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
