WRX Club - Rnd 2 - Phillip Island - March 12
The GTT/GTST time to beat is Geoff/Adz and me all stuck at 1:58s. We should have all done a litle better with the stickies on though:( Adz had fuel surge, i was dropping back to 5 cylinders and had an engine miss and Geoff was beating the tyres up with worn std sups/settings.
My guess on street tyres the time to beat for thre GTT/GTST guys will be a 1:58 and for the semi guys a 1:55.
  • Replies 290
Sounds like Geoff and I WERE on a fairly equal footing before the TT upgrade.....hehehe Roy should be interesting chasing 1:58's on my street tyres and worn suspn. Mental note - take spare pair of undies for turn 1!
ant 2:00 is the stock tyre best for me. i'm entered and should have lotsa pretty stuff today:D
shocks are replaced, new front gtr bar and wing, new stock diff and hoping for close to 280rwkw.....maybe more.
Nice!!
Will you be running that at the track with stock internals?
You bet ya sweet peppy I will be running that. Will be running 10L of race fuel in the tank just for that little extra protection however (no timing advances or power increases with the fuel - just using for safety margin).
And yeah guys Phillip Island is a track where you will continue to take time off of your PB's for the first several times you go at least as it take so long to gain the confidence (grow the wang!) to get the best out of that track. I think from memory the difference from my best time on my first day there and my 4th day there was 8 secs (1.57 - 1.49). Pretty much took 2secs off every visit.
And you will continue to take time off...well at least i do. It may come down to a matter of tenths, but even little old Wakefield after dozens of visits i found myself going a little bit quicker, be it from out braking myself, taking a different line using a different gear/shift point because of traffic.
And INASNT, your weak:)
I know of several RB25s that are internally stock that have done plenty of track days with more power then you with no prob. Bets examples are two other white R33s that are vvery similar to yours. Merli in his old R33 with HKS3040 and 280rwkws, Doughboy with his 2530/T51 Kai/3040 with between 220-280rwkws. Merlis car especially saw at least 5-6 days that i also attended. Then you have to consider the days at Eastern Creek where i dodnt go, plus the days he did at Wakefield:thumbsup:
If im going to run 1.3bar in my thing with whatever power it gets tuned for, then whats your excuse:)
Well I will have to play with my timing and boost setting then since everyone else has up the anti since the last track day i went to, coz my timing is very conservative at the moment and i was only running 1 bar at sandown.
If i blows can i blame you then roy? :rofl:
Ignore Roy he is a serial RB20 killa. Run what's comfortable 'cos when your engine goes it's bound to do it big time at that power.
Well the bits are all coming together.....this might just happen. TT has to equal twice the fun.
I remember doing a 2:08 in the wet at the HSV day (edit: actually it was the PIARC track weekend) taking the high line thru turn 1. Taught me heaps about my lines in one session and I was pumped making the lap stick. All experimentation is good but my yucky rear shocks would have been suicide to go really hard through turn 1.
I will stand by my finding too that a set of MOMO carbon race pedals took 3 seconds off my previous best. Not just rice factor.....Put simply the ability to heel/toe smoothly is a huge benefit.
Denham - Im using the 103 from Rigoli. The advantage of that stuff (compared to the others such as the 110) is that you don't need a log book or anything like that to purchase it.
As I stated earlier it's being used just for some safety rather than performance. As Benno said - for $60 for the day (10L) it's the best insurance you can buy.
But speaking of this fuel - Jack has my drum and I haven't heard if he's actually coming down for sure to this event or not yet. If you read this Jack can you let me know what your intensions are cause if you aint coming I will have to get my drum from you before hand.
Denham, I understand Snowie got 260awkw so usually GTR's get another 30-40 in rw mode. With the higher compression I'll make more specific power at the same boost of 1.2 bar max. The injectors (440) will deliver enough I think and the bottom end is certainly strong enough so it's worth a try.
Geoff - before you go destroying anything be aware that my car was 260RWKW's - i.e. no front drive shaft in (as neither Ice nor Racepace have a 4WD dyno.)
So I wasnt making that power at all 4 wheels.
yeah i think you'll have trouble making 300rwkw... those injectors are same size as GTR... andrew was running towards the max of his fuel system at about 260rwkw, the same as me...
so your goal would probably be around 250rwkw?
Geoff, are you using the rb25 head or have you upgraded to the rb26 head?
There is no way that the same power could be extracted from a std 25 head, when compared to a std 26 head, at the same boost level.
Also are the R34 GTR turbo's ceramic (exhaust)? If so this will restrict you on boost.
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
