AndyCooper Posted February 7, 2005 Share Posted February 7, 2005 Hi people - Is it possible to put a LSD from a 300zx twin turbo into an R33 GTS-T liner? Even an internal swap possible? The 300s seem to have much better locking action than the standard skyline items hence I would like to change. Any thoughts welcome! Thanks Andy. Link to comment https://www.sau.com.au/forums/topic/63868-300zx-diff-in-r33-gts-t-possible/ Share on other sites More sharing options...
randall Posted February 7, 2005 Share Posted February 7, 2005 Hi people - Is it possible to put a LSD from a 300zx twin turbo into an R33 GTS-T liner? Even an internal swap possible? The 300s seem to have much better locking action than the standard skyline items hence I would like to change. Any thoughts welcome! Thanks Andy. Yes it is exactly the same unit externally. some diffs have a 4 bolt drive flange and some have a 5 bolt drive flange, see what your GTS-t driveshaft's bolt pattern is.. I believe the difference lies in non or twin turbo diffs and the ratio's also depends on non/t-turbo diff units. I thought the non turbo's ratio is more favourable.... hope this helps.... Link to comment https://www.sau.com.au/forums/topic/63868-300zx-diff-in-r33-gts-t-possible/#findComment-1199546 Share on other sites More sharing options...
The Dan Posted February 8, 2005 Share Posted February 8, 2005 I think it would be wiser to do up the centre you already have. A diff shop can make them as tight as you want. Link to comment https://www.sau.com.au/forums/topic/63868-300zx-diff-in-r33-gts-t-possible/#findComment-1200656 Share on other sites More sharing options...
The Dan Posted February 15, 2005 Share Posted February 15, 2005 I was told that the centres are interchangeable as long as both are viscous LSD and they don't have any hydraulic connections on the back plate. I was also told that they should be exactly the same. The 300's have better traction because they are heavier in the arse. Dunno how true it is though. Link to comment https://www.sau.com.au/forums/topic/63868-300zx-diff-in-r33-gts-t-possible/#findComment-1210735 Share on other sites More sharing options...
treo Posted March 15, 2005 Share Posted March 15, 2005 does anyone know what ratio's the 300zx have? non turbo/ turbo/ manual/ auto??? Link to comment https://www.sau.com.au/forums/topic/63868-300zx-diff-in-r33-gts-t-possible/#findComment-1250631 Share on other sites More sharing options...
Cubes Posted June 16, 2005 Share Posted June 16, 2005 I'm considering a diff swap for my R32. I find the 4.363:1 diff ratio with the rb30 is simply too short + the current diff is now openwheeling slightly under acceleration. In the wet it some times spins in to a full open wheel. Apparently the S13 & S14 diff's bolt in if you use the skyline diff's back blate. The S13 being a 3.9:1 (Just what I'm looking for) and the S14 a 4.08. Following that there's the R33 & GTR 4.11:1 ratio. The GTR diff being slightly better as it is a mechanical lsd not the poxy vlsd that tends to open wheen when they get hot. The S13 VLSD isn't an issue as I will be getting the diff tightened up so to speak. I've priced around and its around $300-$350 if I remove and install. The 3.9:1 Should drop the rev's nicely for a drive interstate my other half is fantasising about. Link to comment https://www.sau.com.au/forums/topic/63868-300zx-diff-in-r33-gts-t-possible/#findComment-1412650 Share on other sites More sharing options...
Cubes Posted June 16, 2005 Share Posted June 16, 2005 I've done my calcs. 3.9 it is. A shade over 2500rpm will net 100km/h in 5th. 6000rpm shift point will grab Approx: 57km/h in first 95km/h in second 140km/h in third 183km/h in fourth 234km/h in fifth Stretch the shift to just after 6500rpm where it is likely to be once the bigger turbo is on. Approx 63km/h in first 106km/h in second 157km/h in third 204km/h in fourth 262km/h in fifth. I wouldn't want to lean on the 3ltr much more than a shade over 6500rpm. Scared it will pop. Link to comment https://www.sau.com.au/forums/topic/63868-300zx-diff-in-r33-gts-t-possible/#findComment-1413227 Share on other sites More sharing options...
AngryRB Posted January 31, 2018 Share Posted January 31, 2018 Im considering a 3.7 ratio but also going a nismo GT pro 1.5way but what combo of parts from which other vehicles do i use to make this happen? Link to comment https://www.sau.com.au/forums/topic/63868-300zx-diff-in-r33-gts-t-possible/#findComment-7866555 Share on other sites More sharing options...
GTSBoy Posted January 31, 2018 Share Posted January 31, 2018 Um, it doesn't make sense to ask your question in this thread, because this thread started out with a question and answer that do not align with reality. The Z32 turbo diff is an R230, so the internals do not fit into a Skyline housing. And whilst you can jam the R230 housing into a Skyline subframe, it's not trivial. In your case, assuming you don't want to be trying to build some terrible Frankendiff with R230 stuff, then all you need is a 3.7 gearset from an S14 or whatever, plus your housing, plus the Nismo centre and stub axles of your choice. Plus some oil. And maybe a gasket. And possibly some bearings and a crush spacer. Link to comment https://www.sau.com.au/forums/topic/63868-300zx-diff-in-r33-gts-t-possible/#findComment-7866573 Share on other sites More sharing options...
