Guest Boxhead
im just curious, but having an non turbo car, and not looking to turbo it, im wanting some ideas on how i can make it better, as in, better performance, and last longer etc.. i would like to know the cheapest way i can get the car going nicely, and looking good.. all those little things you can do to make your car better
https://www.sau.com.au/forums/topic/639-cheap-mods/
Cheapest option is a good cold air feed and good filter not necessarily a pod either!! Then a good exhaust system, proper tuned length extracters to if you can afford them. Then id say a computer, then cams and head work then individual throttle body injection, then crack the motor start reworking things, stoked bored, cross drilled crank, knife edging the list goes on.... Too look good just put on some nice biggest you can get wheels and lower it that should do any car some justice
https://www.sau.com.au/forums/topic/639-cheap-mods/#findComment-15202
keep in mind a pod is illegal. if you are going to do it make sure you partition it off from hot engine gases. a cheap industrial type insulant can be bought for $5 and if you do a good job of it it can give you a kw per $ return.
check this out. once bonnet is closed, it creates the desired boxed effect. do not forget to provide air feed.
https://www.sau.com.au/forums/topic/639-cheap-mods/#findComment-15664
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
