r33 clicking window
onboost
 Share
There is a load sensor which knows when the window is fully up. If it thinks the window still has a bit to go it will keep going. The clicking sound is your window motor jumping teeth (that's BAD).
Take it to a mechanic and get it fixed.
You could also try another trick.
Spend ages pulling the trim of the door, ages trying to get at the motor and try to figure out what it all means then try to fix it only to find you aren't as good at auto electrics as you thought you might be and stuff it more. This usually ends up costing more money and time.
Less hassle with a professional (most of the time)
 Share
