Another guy is selling a Trust TDO6 20G 8CM its about 2k old, its pretty much brand new $1500 ... see HERE
The turbo is suitable for an RB20 with its 8cm housing. For an RB25 owner you would require a bigger exhaust housing, with Trust recommending the 12cm housing.
If an RB25 owner is interested in buying this guys turbo, then im keen to swap my 10cm housing, which on an RB25 would be very punchy and able to flow approx 250rwkws at about 1.2-1.3bar depending on mods. I have seen these turbos on RB25s make between 240-265rwkws depending on boost.
With the 10cm housing on my RB20 i make about 16psi by 4,700rpm (for 222rwkws) , on an RB25 with its 500cc and extra 0.5:1 compression it would be a lot more responsive and wihtout such a conservative tune will make considerably more power...look at the orientation of the CAS in pic below to see how much the ignition is retarded:(
It is a Mitsubishi 3 bolt flange and require a custom or Trust exhaust manifold and external wastegate.
Or
... if someone is interested in my whole Trust TD06-20G setup including manifold, wastegate, dump, ECU, IC, pipes etc etc, hell even the RB20 engine and gearbox (any S13 owners?) then PM me to discuss what it is your after.
https://www.sau.com.au/forums/topic/63930-want-to-swap-or-sell/
Well i have sussed a new 8cm exhaust housing:) So if noone want to buy the turbo kit for approx $3000 depending on the parts you want with it, in the next 10 days or so, it will be staying on my acr until disaster strikes:)
    • There's a fair chance that my bushes are Nismo, because I'm reasonably sure that when asked the question (when putting the subframe into the car in ~2012) "What bushes do you want to run?", I'm pretty sure I would have answered "The stiff ones!". I had to put some silicone grease onto the GKTech inserts I jammed into them last week, because the bushes were quite resistant to having something jammed up their jacksies. So, I reckon you'll be best off doing Nismo + inserts. And, if I'd known you had PU bushes in the subframe AND PU pineapples, I perhaps would have said earlier that that's probably not a good idea. The pineapples are only intended to work with the stock type bushes, because those have a crush tube (which is what makes it end up looking like there is sloppy space in there - but doesn't, because the crush tube does make contact steel to steel) and the pineapples live in the space between the subframe's outer tube and the lower washer/bracket. But the PU bushes don't leave the space in the same way that the stock format ones do, and they do end up fighting for space. Order some bushes and collars and get to it.
    • Thats the current state of the reo. Bit ew, but GTR Reo and supporting bars are $2000, and 2nd hand GTT ones are $1000... More engine disassembly. The good news is   Various LS weird sounds are apparently normal Everything coming out is in perfect condition The bad news is: Everything coming out is in perfect condition It looks like whoever assembled this engine ~25,000km ago was telling the truth with what's in it and how they did it. Even things I was unsure of like the timing chain - But it's a brand new double row timing chain, spaced perfectly. They even cut up the stock windage tray to keep it instead of being lazy and to work with the baffle. Cam, Heads, springs, LS7 lifters, Pushrods - All look new and have obviously been working perfectly. In other news, we removed the pineapples that were loaded below the superpro subframe bushes. They look a fair bit munted and have deformed the poly bushes that are 'above' them. I'm telling myself that now that there's space 'under' the bush between the little cup that bolts in... that having a pineapple wedged there was bad and basically made the rear end solid. The pineapple and the superpro bush are ... equally deformed (i.e they have deformed one another from being smashed together). We'll see how it goes with bushes only. I am sure this cope will fail and the answer will be to drop the subframe and put nismo rubber bushes in there instead. $400 worth of gaskets and ARP head bolts to replace perfectly new looking gaskets that absolutely weren't leaking  and were installed perfectly with great care - because god damnit.
    • Why bother? Keep them under 1bar and be happy, I had it for 10 years and never had an issue. once you go beyond that the budget blows out fast and then keeps on blowing out
    • I'd still recommend rebuilding the turbos too. That will eat up a lot of the budget especially if you aren't willing to put in the labor to R&R the turbos yourself but it's a huge risk to ignore it at this point.
    • Can't help it, its an illness.
