I go with the F20C as well - that article is done from a euro point of view as well, the Japanese spec one is around 250ps... ie, the same as an RB25DET :)
They are reliable, sound awesome, light, economical, are smooth, have low emissions, make awesome power for an NA motor (hey, they are higher than a lot of equivalent displacement turbo motors), and are really tractible etc. And they aren't on the razors edge to make that power, do an intake, exhaust, ECU and tuning etc and there is still more to be had. One of my mates was making over 150rwkw on his mildly modded S2000s, which makes for some fun driving :(
There may be some limited run NA motor that matches its peak power/l - but I doubt that motor can match the F20C in the other aspects... it might also be peaky as a mofo and not actually end up being as good an overall performer. The F20C is a jack of all trades in its displacement range.
So if you drive it like a pansy you can get 13.6L/100km and some of you are saying thats economical???
And isn't there a torque difference between an RB25 and an F20C?
As for Chryslers, how is a 225 slant better than a 265 hemi? I've been in a Charger with 265 that could spin the wheels with ease in 3rd and 4th gears at speeds well over 100km/h. Admittedly it idled like a plate of jelly.
Considering standard production engines, Honda make some great ones, F3 and F4 CBR 600 (motorbike) engines, F3 is prolly a better engine but the F4 is fuel injected. The sequential gearboxed on these engines are great.
How can you look past the Ford Windsor V8, designed back in the 1950's, the same basic design is still used in both ford production cars and V8 Supercars.
Turbo 6: RB26DETT (Of course. Closely followed by 2JZ-GTE)
N/A 6: Hard pick, 265 Hemi (1/4 mile champ for all Aussie made cars till 96-V8s included) over 186 red motor (need some work to make em go, but they rev like mad for an old pushrod heap).
V8: 350 Chev- widely regarded as the best bang for buck drag engine available.
Turbo 4: FJ20DET.
N/A 4: the 1400 in my sister's old rwd 323. It took a thrashing ;) , never missed a beat, and was amazingly simple to work on. SOHC & crossflow head not bad for 78.
I wouldn't go past the new BMW 4.8L 2nd gen valvetronic engine. There really is no better car engine in the world. With infinitely variable valve timing AND lift + 4.8L of capacity, what could be better?
If I were to choose a 6, it'd be the VVTi 2JZ-GTE.
If the argument is (and I'm not saying that it is) that the greatest engine is the "winningest" (nice word huh?) engine, then the Chevrolet small block V8 would be first with daylight second. This engine has won in everything from jet boats to speedway and everything else besides. Admittedly there ain't a whole lot of Chevrolet bits spinning around inside them but they were originally a Chevy small block designed by one of the greatest engineers, Mr Duntov.
[And it's fuel efficient in that one can - 'one' I assume being someone limper of wrist - drive to an average of 13.6L/100km (32mpg). Hell, it even looks good, longitudinally mounted as an engine should be.
When is 13.6L/100km 32 mpg? I thing that around 9.6L is 32mpg. What do you think?
13.6 is 19.8 mpg.
Sounds like the pom failed maths
Well the greatest engine of all time has to be.......................
Drum roll
>>>>>>>>>>>>>> Scram Jet Engine <<<<<<<<<<<<<
Well im fitting my scram jet engine next week. Should be able to do 0-100 in a half a second and 100-1000 is .23 of a second, but yeah there is some fearce competition out there with the GTR's so im not overlly confident.... LOL
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
    • ...oops. forgot the TCU end...
