Hey guys,
question.......
I have had a K&N pod filter setup since I have had the car, and a friend mentioned that the standard air box seems to work better than the pod setup.
Is this true?
If so, I have just installed my standard air box with a new K&N air filter for it and it seems to be a bit more restrictive. Boost does not seem to come on as high as it used to and when "blipping" the engine to about 2k rpm the revs seem to drop alot lower (drop to just under 500rpm)than when I have the pod on, the revs then seem to creep back after a few secs. The pod never seem to lose revs. Obviously there is a noise difference aswell.
What do you guys think?
Anyone tested the pod vs the standard air box at all?
Could it be that the car was used to a certain air flow which has now changed?
Which is better?
thanks.
BOOMAU
https://www.sau.com.au/forums/topic/63949-pod-filter-vs-standard-air-box/
As for testing the difference, I'm sure you'd find a few threads that cover this. Anyway, I'll answer your question.
The pod filter is probably going to be better for flow and total surface area.
The panel filter is better as it restricts heat from engine bay entering.
What you need to do is make a shielded area for your pod filter that seals (for the most part anyway) when the bonnet closes thus creating a sanction where hot air cannot enter. This gives you the best of both worlds.
People usually use aluminium as it is easily cut and shaped. Then use sticky heat shield tape to keep the heat out.
I actually relocated my filter down to where the stock intercooler goes. Seeing as though mine is no longer there. The only problems I have is filter changes are much more often. and when you drive through a puddle during rain it sometimes makes the car stall coz you suck up water. I made a quick release for it so I could return it to its natural position during rain and move it back again for more power. Kinda a pain in the arse but that's what I get for owning a sh1tbox
You obviously changed more than just the pod to lose 56kw.
I changed from a HKS Pod (unshielded) to the std airbox with K&N Panel filter. From memory the car felt a little more responsive downlow but it's been about 18mths now so I can't be so sure. I don't get any hassles from cops (after being hassled by a defect which is why I changed in the firstplace) and i'm guaranteed clean cold airflow because of the std air scoop. I also didn't like the "whoosh" of the HKS Pod.
My car is making damn good power (for my mods) so obviously the K&N Panel isn't holding my engine power back otherwise I would have swapped back by now.
Why spend $200+ on a Pod and then modify your engine bay just to fit it when a K&N Panel filter costs ~$100 and takes not even 1min to fit without any modifications at all ??
search is a fun tool :D
http://www.skylinesaustralia.com/forums/sh...ead.php?t=62907
read that topic - everyhitng you want to know will be there
and BazR33 - i doubt you lost thast much power - I have seen dyno sheets to back-up that if a POD is not enclosed in a partition/CAI Box you will LOSE power - but using a POD in CAI and a High flow K&N panel in the stock air box you would't lose 53KW's
After reading the whole post, it seems that there is no real difference either way. For a gain of 10kw to set up a pod, and a box sounds like it is not really worth it. Although seems as tho the air box is a bit restrictive at high rpm.
Still doesn't answer the question of my revs dropping since I installed the standard air box though.
I think that I am going to revert back to my pod which was sectioned off, may look at adding a pipe from the lower front spoiler up to the pod for more cool air.
Thanks guys.
BOOMAU
    • Uncle Duncan Yeap, FI Interchiller  Works well, normal IAT's cruising with the WTA only went from 50°c+ to 25-30°c with the interchiller  Before, when on it hard, the IAT would see 80-90°c, now, the highest has been was around 38°c IIRC I recommend it for the street or strip where your only on it hard for 10 or so seconds, but it wouldn't be efficient for sustained track use as it would heat soak from the AC turning off or whatever it does during WOT to protect the compressor It really needs the AC running for it to not heat soak and keep the WTA coolant chilled My WTA coolant temps when just cruising is around 2°c
    • Hey Mark...sorry to interrupt your career change to hair dressing... but...did you ever fit the interchiller to the commodore, and if so how was it? And, who made it?
    • I've been pondering this, I really enjoy the convertible thing, for me, it's like riding a motorbike, without all the issue of riding a motorbike, mainly, my old sore arthritic joints getting beaten up, and, being able to do it in shorts and a T-shirt and not needing a helmet and all the other gear required, especially like wearing jackets and pants in the summer, or needing 6 layers of cloths in the winter, or not having wet weather gear handy when your 100km away from home on the bike when it decides to start raining As for the hard top and its Coupe look, whilst I do lose all that open top feeling that I really enjoy, from my experience with the NB with a detachable hard top, the cabin is a much nicer place to be, the difference in noise for one, a hard top quietens down the interior, alot, with the soft top up or down it's pretty noisy, which, after 5 or so hours, can get tiring But, as you stated, the detachable hard top totally changes the look of the car, in a really good way, and for me, the look of a detachable hard top is so much better than the PRHT which looks more like a after thought with its weird bulbous rear roof line For me, the minimal effort of putting in on, or storing it after removing it, is well worth the time and effort for the look alone And yes, I'm sure the next owner will be grateful for it as well.......
    • I get into huffs with people when I suggest the MX5 looks so much better as a coupe than it does as convertible. Pretty sure I don't prefer the convertible version of anything. Good job on the hardtop! The next buyer will appreciate.
    • IMO wrap does have its uses, but like you said, quality wrap, and professional installation, would probably cost want a quality paint job does, but, the paint, if maintained, is basically for life, and much easier to touch up if required  In other news: it's pissing down here, with thunder, lightning and only some small hail "at this stage", luckily all "my" cars are undercover  I've also been contacted by a guy in Newcastle about the SS, he said he will come down next weekend for a look, we'll see how that transpires I guess 🫰
