I had my mine approved about 2 weeks ago without dereg papers. I just sent the form along with full details of the cars and invoices from the supplier.
Hope that helps,
Andrew
this is apparently my de-reg paper
i dont understand how it would have any meaning to dotars tho, as far as i can see there isnt even a date of first registration on here, unless its in japanese
That's because its using the Japanese date system, which relates to the year of the Emperors reign (in this case, Heisei).
The third box along the top (that reads "(Jap. Character) 2 (Jap. Character) 5" means your car was built in the fifth month (May) of 1990.
DOTARS uses the de-reg papers for proof of age, not proof of first registration.
LW.
Yeah also, if your car is already past 15 years to the year, they don’t really mind you sending an import approval off with out the deregistration papers.
I.e., my car is built 1989, September, I sent my IA off in February, but because it wasn’t a 1990 model, it wasn’t necessary for the deregistration paper work. Well thus is what was told to me by my custom agent.
  • 2 months later...
I think what Geoff is suggesting is that you should lodge your application immediately, even if its somewhat incomplete.  Once its lodged they will find it that much more difficult to deny you an import approval due to the new rules as its already "in the system" so to speak.
I would follow Geoff's advice, but fully expect to get a call from DOTARS asking where the deregistration papers are.
LW.
The only trouble with this advice is often dotars just don't call..........you have to do all the chasing. They'll be flooded with Import applications in the next few weeks until the law change is gazetted, so don't be waiting for them to ring you!
I jus got import approval the other day. It took a while as I faxed off the application form without the proof of month of manufactur, i ended up getting a fax requesting 'proof of manufacture date', so I called up Nissan Australia and got them to write me out a letter confirming the date of manufacture. No problems!
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
