Hey guys,
I am thinking about getting some new wheels/tyres for my r32 gtst this weekend.
I currently have the stock 16inch with pretty good tyres fitted. I want to get some 17", as part of a deal, you get tyres as well.
Questions i have are,
There has been previous suspension modifications done on the car, so it is quite a stiff setup and handles well. Am i going to notice a change in handling with the 17inch rims, as in, a rougher ride with less rubber, and low profile tyres.
What you think of getting just 16inch rims of the same style and fitting my current tyres, as they are quite new.
I would prefer to get 17inch as they will look nicer, but i don't want to compromise handling and drivability (sp).
Just as a sidenote question while i am posting.
Will this affect the brake set up at all?
Any feedback is greatly appreciated.
couple of things to take into account..
17" wheels will have a higher weight most likely which will affect braking, turning, tramlining etc
however the width of the tyre will affect the tramline effect!
slightly bumper ride due to harder side wall on a lower profile tyre.
most of this your would more than likely not notice at all.. but specifically asking if you would notice .. maybe some aspects however i dont think it would compromise the handling of the car!
in fact harder side walls would promote better turn in on initial weight shift anyway!
Well on my shitbox daily R31 I changed from the stock 14s to 15 inch rims. I cant comment about handling as its never driven hard around any bends.
But on the pothole and bumps issue I was literally astonished at how much more I could feel every little imperfection on the road compared to the 14s. The ride was noticably more harsh.
But in performance car applications, I guess it would be a positive to "feel" more of the road.
    • Once the belt slips it can very easily cause a cascade that encourages more belt slip. Check the pulleys carefully and see if the grooves have cupped. If it has it's time to replace the pulleys. If the rubber has glazed you also need to replace it. Shouldn't be shiny. From the factory there's a lot of exposed fibers(?) on a v-belt that will go away as it's broken in but some should still remain visible without sticking out significantly like a new belt. I went through this on my dad's Camry recently. It would keep slipping even after setting the tension higher, only solution was a new belt.
    • Belt polished and/or pulley(s) glazed. Rub pulleys with sandpaper, replace belt.
    • I've also got a quick jack. I would never get under my car again without using it.  While it might be quicker to use a jack and stands, it is such a quality of life improvement that I wouldn't have it any other way now.  How much slower the quick jack is to setup will be based on your circumstances. Can you leave the jack rails on each side of the garage? Can you leave the hydraulic lines attached? etc.  If you can drive the car into the garage and simply push the jacking rail thingos under the car into place, it is super quick to setup and use. But if you have to pull the pump unit out of storage, attach the hydraulic lines, wheel out the lifting rail thingos.... yeah takes a bit of time. Having said that, I would still prefer that to using a jack and stands lol.
    • Sydney Tools have them for ~$3400. More than the Quick Lifts but these seem better. https://sydneytools.com.au/product/quickjack-7000tl208240v-5175642-7000lb-110220v-portable-light-duty-truck-and-passenger-car-lift-system
