If you wanna get one done on your way through. Stop in at Brissy and I can organise one through work. We get a third party in to write the RWC for us. He does a basic inspection but relies mostly on our extensive inspection of your vehicle *wink*.
Seeing as though it's an import and I drive one, my boss is a bit of a toss so he'll give it to me to inspect.
It'll give you an excuse to have a bit of a look around in brissy on your way up and as long as there are no major defects I can pretty much assure you of a pain free RWC.
Pm me if you are interested.
This option available to semi locals Dan? I'll be needing a RWC or 2 in the near future...
Wellcome to Cairns
I am a new import owner but a lot of blokes up here are very friendly with good advice, will probably see you around sometime. :P  :)
Gary
Thanks Gary, hope to see you round too... Stagea hey? Cool!
for a (rwc) in just pull over one of the cars that has a prospool sticker (skyline,silvia) and ask for a bloke called stick thay will help..
Ta kid, does 55Nat work for Pro Spool? just reading his sig...
LOL, they are the best types of RWC... thanks heaps for the offer :D but unfortunately I will be running on pretty tight schedule and have to get up there for work. Thanks again!
I recommend running your Vic rego out till the end. You lose allot of money if you try and get a rebate through fees n shite.
As already mentioned if pulled over and asked how long you have been living in the state tell em less than 2 months. Then switch over the rego to Qld. I did this for 10months on Vic rego.
I agree with Shane.
keep your rego as it is, including your license.
Don't worry too much about the RWC coz Qld's laws are alot easier than Vic esp. if you have mods.
there are places here that are anti import (backwards types) and will tell you that you can't buy parts for them etc etc.
True, but the cost of the parts is significantly higher than most local cars.
A good example is coils :bs!:, plus the further you go north the more expensive they are ie freight.
mmmmmmmmmm........It's beautiful, Cairns is nice, enjoy your stay!
Thanks!
I agree with Shane.
A good example is coils , plus the further you go north the more expensive they are ie freight.
Cool, I'll do that, just use up my VIC rego, then change over. The RWC should be fine (hopefully) I have put my car back to BOG STOCK now anyway, just to be sure.
Have any of you local guys/girls used Ray Hall Turbo Charging ?
  • 1 month later...
OK... I made it in one piece! But I will never do it again... 3500 farking kilometers!!! Got a speeding fine on the Leichart HWY - 118 in a 100 KM zone, had not seen a car all day then over a hill comes a bush wacko QLD copper from Banana! hahahahaaa, what kind of name is Banana?!?!
If you want to really fu(k your duco up, then do it! Stone chips, bugs and all kinds of other nasty things bouncing off the car, but I spent all day yesterday cleaning her up and looks a treat again, just need the front bar resprayed.
Well, I've been here for three days now and have seen a black 180, a green soarer and a black soarer...
Will spend this week trying to find a workshop that can give me a roadworthy certificate, so I can transfer my rego over. I think I will get 'QLD - The Smart State' number plates... hahahah NOT! They are as bad as my VIC ones 'VIC - The Place To Be' NOT!!!
Anyway, would love to catch up with a few of the locals! :P
So Lukas what kind of work are you involved in? Do you have to find work in cairns?
I am a Real Estate agent. I don't have any work yet, but the real estate industry is pretty good up here. I am speaking to a couple of offices early next week. But open to an offers of other work (retail, sales, etc...) :cheers:
    • Good points thanks. Unfortunately I can't seem to rename this or delete the topic. Seems like I'll ask the moderators to change it or delete it.
    • You might want to update the thread title.  V37 ≠ V36.  And it probably isn't a G37 unless it is 2012+ Ininiti or LHD.
    • Just a basic run down of the relevant bolt-ons. All e85 First graph 406.9whp is HKS GT-RS, HPI manifold, 3" bell mouth dump / 3" straight through fake cat / 3" all the way to the rear and no resonators, nismo 740cc, walbro 460, oem RB26 itb's, power fc, eboost2, Greddy Spec M fmic, poncams, Turbosmart actuator, splitfires, ARD 150amp alternator. Blue line is same as above but Blitz Dual SBC (before i upgraded to eboost2) and 100cell "high flow" cat. Red line is after installing eboost2 and the fake 3" cat (it's just a 3" pipe with a cat shell welded onto it). Huge gains in response, as can be seen. Black dots are a mates sr20 with almost identical setup but uses a garrett 2871 instead oh HKS. Next grapghn 466.6whp is same as above, but HKS 2835 Pro S with the larger .87ar turbine housing, the special HKS Pro S dump pipe into a HPI split dual 2.5" front pipe and the rest stayed as is. Red line is after I welded the actuator brackets. (It was originally bolted together and was moving a couple millimetres under load). Green line is obviously before I welded the bracket, no other changes. 100whp gain at 3750rpm, massive gain for such a simple fix. Third graph is my current setup, huge changes. 469.7whp R31house twin scroll manifold, twin TiAl 38mm gates, Forced Performance (USA) HTA3076 with 1.01ar twin scroll rear housing, Link Fury+ and loom by 12volt, PRP trigger kit and r35 coil kit with r35 splitfire coils, HKS step 1 vct staggered cams, new oem lifters and performance springs, 49mm itb's w/port matched Nismo plenum, twin walbro 460 surge tank setup + 1650cc injectors, HKS Type R S13 600x300x103mm fmic, individual egt's, 4" turbo back with no resonators or cat and AES true straight through muffler + 4" butterfly off the dump pipe lower 90° bend. It's a preliminary tune with no boost control with using 20psi gate springs and 4" butterfly closed. Once body loom and PDM is compete, will go for 30psi tune.
    • Power light apparently functions as a transmission error light, you can try the power sequence to read any codes from the transmission control unit.
