Apexi Engineering Power Fc For Rb20 Only
Jonneh Bravo
 Share
hi guys i was just wondering how many of you want power fcs for an rb20 r32??? i have sent in a few emails regarding the best prices i can get. i have estimated around 10 - 15 people would want one at the right price. i have noticed alot of people trying to sell PFC's for r33's and r34's but no one has made an attempt to obtain a excellent price and order a few of these. i should receive and email either today or tommorow regariding prices so purely looking for interest now. could people just post if they are interested.
thanks
jon
So far the best price i have got is $1500 delivered. so what do u guys think??
ok interest so far:
1 - Cubes
2 - Black rb20 silvia
3 - Jaystar
4 - wizard2k
5 - nf
6 - drifto
7 - 46n2
8 - R31 Koop
9 - Masters
10 -
the reason there are more for r33 and r34 as its a stock apexi unit
there is no stock apexi unit for r32, its ap engineering one which is like a remodel of the r32 ecu to support powerfc interface. usual retail is like 1600+ normal powerfc is only 1000
These PowerFC's are the latest version that also comes with the handcontroller bundled?
Nengun have them for some where up around the $1600 mark.
Greenline have the previous AP Engineering PowerFC that wasn't bundled with the handcontroller.
The PFC Pro's only real feature is its ignition cut vs the stock fuel cut when you bounce of the rev limit.
It also has a little feature of allowing a launch controll if you like which holds rev's constant until you pop the clutch.
That last feature is ok but I honestly wouldn't bother with the Pro version UNLESS you were planning to run NOS or just wanted the bling rev limit launch control feature.
Depending on the type of NOS system you run the stock fuel cut on the std. PFC will blow the little ol RB instantly.
I could see the launch control feature being handy with the rb20 though.
The RB30 doesn't need it.
Don't get me wrong though... I'm not nocking it or you Razor at all. ;)
Back on topic..
Do these PowerFC's come with a handcontroller?
 Share
    • Its likely to be 70% road 30% track usage, track usage will increase if anything. Decided not to fit it as I cant be arsed changing the bushes on my LCAs again 🤣 I did get the below back from GKTech though so they should work together     The anti-squat kit and roll center adjusters work independently since they change the rear lower control arm's angle in different ways. The anti-squat kit adjusts the angle from front to back, which impacts anti-squat values. Roll center adjusters change the angle side to side, mainly to correct geometry on cars that are significantly lowered. They might affect each other a tiny bit, but overall, you can think of them as separate.
    • What are you doing with the car? street car or race car? People get hung up on the squat of the s/r chassis rears. There is positives to the squat if a car is setup and driven correctly for it (correct ride height, spring rate, alignment, damper valving). Generally just lengthen the rear traction arm by 5-10mm and that will help the squat and bump steer too. You are also correct with the roll centre too. This too also needs to be adjustable if you start messing with suspension geometry.   Having done quiet a bit of testing on race cars this year in regards to rear squat, I've seen some big positives from it in regards to drive off corners and traction.
    • I find I am using the MX5 for everything except long overnight cruises with Jackie, or, if picking up the kids to go somewhere, the SS has so much more room inside, and is much more comfortable if your going to be doing Hwy driving for 6-8 hours And the MX5 isn't bad in stop go traffic for a manual transmission car, whilst the clutch kit has been upgraded from stock, it is still light, and also not having a stupidly light flywheel in it helps as well, I've spent alot of time sitting on the M5, M4 and M7 stuck in traffic when plodding around the Greater Sydney Region in it Another benefit is MX5's are not really a car that gets stolen, you can pretty much park it anywhere, and it will still be there when you return
    • I can totally get why you like it for that sort of commute. I was thinking BoganDore because it's such a lazy drive, for things like stop start traffic.   I used to do over an hour in stop start shit from one side of Bris to the next, twice a day. My choice of car was larger displacement, with an auto. Basically for torque in low rpm/very low speed, and no clutch pedal. But loved a fun manual for the weekends, which the partner has (plus had the LandCruiser too for other fun drives). I now have an EV as a work car, and I tell ya what, ultimate daily driver, especially if youre out of energy, like I often am after work. I don't even need to touch the brake pedal   That said, I'm presently rebuilding the Liberty GTB to get it setup for weekend drives and track abuse! So small high revving turbo engine with 6 speed cog swapper!   But for your style of commute, I'd probably take the MX5 too!   For those choices, I'm ignoring fuel economy. Because I know how atrocious V8 daily life is for fuel from when I used to daily a manual SS, ha ha. Hence why I know I love the daily rumble of a V8
    • II know what u are saying after 9 years of hibernating my stock engined  110,00km gtt I got it registered 2 weeks ago. Took it for a drive a couple of days ago and some fresh bp fuel, I just couldn’t stop grinning and dreaming of when I will start my build thread. its just such a primal man feeling many forget to enjoy I wish u so much enjoyment with your little racer mate
