Hey folks,
My motor blew (Big end) on Monday evening leaving the carpark at work doing about 5-10 kms per hour.
I wasn't going to post but I have received alot of calls, PM's and alot of SMS's re the destruction of my RB26dett. Some of you I have spoken with and others have just heard through our network
What caused it I dont know, maybe the history of the vehicle in Japan. I'll be trying to find out more when it's eventually pulled out and dissasembled.
I was extremely thorough prior to purchase and treated her very well since I bought her 3 months back. So I'm a little baffled.
But Sometimes Sh!t just happens, You get over it.
:wavey:
Thanks for your kind offers of lifts to work etc...I'll holler if I'm stuck
https://www.sau.com.au/forums/topic/64015-big-end-blown-big-buck-rb26-debt/
  • Replies 81
Like a said to you this morning, "thats fcuked" on a lighter side maybe you should have drove it like i drive mine. Oh hang on mine has been on and off the road more times then I change my undies. lol.
But sorry to hear richard.
if u want some help workin on it id love to help!!!
im with gus, if you need anything, holla at me
well this weeks been pretty gay, possible cancellation of the cruise and one of the nicest GTR's in ACT is now off the road... WTF?! why is it now that the sh!t hits the fans?
Sinista32
Could be time to slot in an N1 or Newish R34 RB26
Not shur what type of computer ya running and the compatablity of parts but it could be good/better value for money than a simple rebuild
Smaller Labour costs
Get the car back quicker
Dead engine out
Good engine in...
(gestimate... 2 weeks )
Or
Dead engine out
Rebuild engine
Good engine back in
Appropiate Engine Run-in (various reves- various gears)
(gestimate 4 weeks)
Just something to think bout!
Some guy posted up an R34 or N1 engine look into it.
Bad luck
When you're taking the bottom end apart, don't have any alcohol around, you don't want to make any mistakes there :)
At least pull the motor out and take it apart. Have a look see how much damage you've done. You'll also be able to get a good idea about the condition of the whole motor (provided you've got the right tools) - and with these things information is power - make a decision based on that.
Keep in mind, if you buy a second hand engine, you'll be buying someone elses problems, and quite possibly the same thing will happen again. Unless you are 100% sure you've got a good motor its not really worth it long term - you're better off rebuilding what you have at least you know it is sound.
Just my experiences :P
PS was that Mark from QLDs old car?
will miss seeing sinista on the streets.......and the offer still stands if you want to get behind the big thumping V8, complete with bundy stickers, and of course the huge bullbar, which really attracts the chicks!!! Let me know if you want the keys to this good old aussie icon.....
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
