hey Guy's, put my car on the Dino the other day down at evo in fyswick just to see how much power my pritty stock r32gts-t put out. i got a reading of 137.4 kw at the rear wheel's wich is about 185 bhp. I was just whanted to know if any one can tell me what that is a the fly wheel, as stock its suposed to be 160kW @ 6400rpm (214 bhp) and just whanted to know how much more power mines got from stock!
Thanks
some say theres as much as 20% loss through the g/box, diff etc, but it all depends on the types of g/box, diff. there was a thread about drivetrain losses in another section a little while ago, cant remember where it was though.
what mods have you got?
It's hard working it out in reverse as a %.
I think the expected losses are about 50kw for a manual rwd R33 gts-t, and around 60-65kw for a manual 4wd (GTS-4 or GTR). Higher again if you've got an auto transmission.
So a manual R33 GTS-t at ~180kw at the motor comes down to ~130kw at the rear wheels.
Remember that your motor generally won't be putting out what the factory spec's are due to the age/wear etc..
J
list of mods:
Greddy Large front mount Intercooler,
Cusco Aftermarket coil over Ajustable suspension
GTR front spoiler
17 inch alloy wheels
4 inch Apex Exhaust
Strut brace
blitz Air Pod
hks Blow off Valve
    • Sounds like it is rotational in the driveline. CV? Tailshaft CB? Also.....didn't you just pay to have that bit painted and put on the car?
    • Yeah, when I dialled my idle down, given how much time I spent idling at the lights in traffic on my daily commute, the effect on overall fuel consumption was absolutely noticeable.
    • Emissions, fuel consumption, heat, noise, etc. most likely.
    • For me at least the reason why it bothers me is because it's indicative of a deeper problem. And that will nag at me forever. Especially because I have tailpipe emissions testing + evap leak testing every 2 years.
    • WELP. I went to the track, and I suppose it went okay because any time you can drive home is okay. You may notice the car is not on the circuit in this picture. It was about 35C day out in Benalla which means the track was approximately the surface of the sun, probably. Good things, car did not overheat but it _was_ warmer than when I had done track days in similar heat before, I think, I'm not sure - I can't quite remember. Coolant got to ~105 via the ECU after 20-30 minutes of belting it in said heat. Oil got up to 145C in one instance which is pretty crazy due to oil cooler. Pressures were fine. I seem to remember this not getting quite so high before the vents. More HMMMM'ing to be done. On the subject of HMMM'ing, can anyone identify the sounds in the video below, you will know which ones I mean: https://www.youtube.com/watch?v=uj3BkI2cbTc I included some 'normal' sound as a reference for the first minute or so. The microphone in this instance was where the license plate is. It stopped working later in the day which is why my "best example of a lap video (not produced)" had internal audio - Isn't hearable from inside the car. I don't mean the chirping of the un-bedded/badly bedded track brakes which you can only hear while braking... Thoughts, brains trust?
